riivian
2022 Rivian R1T & 2023 Rivian R1S
Dynamic Glass Specialist
In both the R1T and R1S models, I’ve encountered issues with the suspension feeling excessively hard when hitting cracks, bumps, small potholes, and manhole covers. Both vehicles had undergone service for the clicking, ticking, and squeaking suspension issues. The common fixes included replacing washers, hub bolts, half shafts, and in some cases, subframes (for the R1T).
Despite undergoing service, the hard ride quality persisted. It seems that a recent update in the past couple of months might be the culprit, but I’m not entirely certain.
Determined to find a solution, I decided to “exercise” and “stretch” the suspension by putting it in Off Road Mode and raising it to the Highest level. I drove the vehicle for a few minutes at the 20 mph maximum speed, then switched to Performance Mode and set the settings to the Lowest with Firm setting. I continued driving in this manner for a few minutes before reverting to Auto Ride Height and Soft settings.
To my astonishment, this simple adjustment completely resolved the issue. The suspension now effortlessly glides over those mentioned scenarios like it used to in the old days. I’m sharing this experience to see if anyone else has encountered similar problems and has tried this method. I hope this information is helpful and serves as a significant game-changer for others. Surprisingly, simply switching from High to Lowest settings did the trick!!
This also works for my old, beat up Rugby body.
SASSquatch
Washington DC
BMW i3s Ford C-Max Hybrid
Semi-Autonomous Yeti
Rivian R1T R1S Harsh ride issue fix: exercise (calibrate) suspension -- raise to Off-Road Mode + lower to Performance Mode 1728261651032-go
riivian
riivian
Yes, this was a significant solution to a persistent issue that had been bothering me. I suppose what occurred was that it re-trained it to the extremes of high and low to calibrate it. That was my hypothesis, and it worked!
NoGoingBack
Ohio
F150, R1T
Information Technology
I’ve done something similar to refresh my suspension as well. I’ll give your method a try next time.
I have air ride on my motorcycle and I need to refresh the suspension like this every so often too.
jmtreetop
Jon
The question will be how long does it last. I find a lot of variability between days. Some days I don’t hear any noises and other days it’s incredible noisy without any rhyme or reason.
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
I have noticed that cycling the suspension through even part of its range can sometimes reduce the deadband in throttle response as well. I wasn’t paying attention to suspension response but I will now.
Interesting observation, thanks for posting.
I had minor suspension noise when I first took delivery but it went away after a month. I use Sand mode for off-roading 2 - 3 times a month so the suspension is getting that range of motion every few weeks. Perhaps that's why my suspension noise went away....
WorldComposting
www.worldcomposting.com
Rivian R1S, Subaru Ascent
Project Manager
Great to hear this worked. I noticed something similar after showing people how high the vehicle can go. I never drove around but I might try that next time.
Did you need to do this each time you drive or just once then it got much better?
kanundrum
Washington, DC
Did this, got a Christmas tree of CELs, gonna have to tell my mom I'm filing a lemon law claim.
Bradyb23
Brady
Santa Barbara CA
2025 R1S DM
Thanks very much for posting this. I've experienced what I think is abnormally harsh suspension in the soft mode and have been dreading getting a service appointment (100 miles away) to have it looked at. I will try this first. Mine is a Gen2 with 800 miles, picked up on August 29.
Out of curiosity, can anyone point me to the best threads on other common issues for which folks have found self-help solutions? I think someone mentioned wind noise, the horn, and something else. It just occurred to me that I haven't even tried honking the horn yet...
