mkhuffman
I am not a fan of the glass roof. I love opening roofs because you can, well, open them. But as a driver sitting in the driver seat, a glass roof does nothing for me except make me hotter or colder. And my wife hates it because she doesn’t like sun shining on her face.
The easy solution to reduce sun exposure is a simple roof cover, like this one from Hanshow:
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086006-01
https://www.hansshow.com/products/rivian-r1t-glass-roof-sunshades?variant=45676072599764
That is the one I have. It works great except it billows when the windows are open. I do wish it would be more stable in that situation, but other than that, it works really well. However, it is not insulated.
To get a real benefit, insulating the roof is key. Reflective surfaces are great for reflecting heat, but do you want to reflect out the sun in the winter when that extra heat can help warm the cabin? No. But reflecting out the sun in the summer would be good.
In the end, I decided that cold temperate efficiency is more important to me than warm weather efficiency. And Rivian already does a good job with the glass roof regarding warm weather performance. I can turn on the shade, and it blocks the heat pretty well. Cold temperatures kill range and heating the cabin is one of the big reasons.
To retain as much heat as possible, a reflective surface faced into the cabin is best. Even better would be an insulated shiny surface. You can get sheets of that kind of thing from Home Depot, but mounting them to the glass is a challenge. And it will be ugly. I do care somewhat about the appearance inside my truck.
I have used this before to wrap ducts:
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086044-hn
Frost King E/O 1 ft. X 1/8 in. x 15 ft. Self-Stick Foam/Foil Duct Insulation FV516 - The Home Depot
It is self adhesive, so it is easy to put on. And the foam side that sticks to the glass will absorb sunlight, hopefully not blocking too much of the heat in the winter. The other side is reflective, and should really help reflect the heat back into the cabin in the winter.
I put a strip on the glass as a test, and then covered it up with the Hanshow glass roof sunshade. I left it like that all summer and up until last night, so I could do measurements on how it performs in the summer and winter.
Here is what one strip looks like:
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086125-
In the summer, I turned on the roof for extra sun blocking. In the winter, I turned off the roof to let in as much sun as possible.
In the summer I was very surprised to measure a significant difference in temperature where the insulated wrap was applied. On average, on hot days the insulated glass was 8 degrees cooler than the non-insulated glass. Amazing.
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086195-cf
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086261-xf
To be clear, when measuring those temperatures, I had been running the climate control so the interior was being cooled and with the full heat of the summer sun shining down on the roof. The temperature difference between the insulated and non-insulated roof was almost the same if the air conditioner was not running. That is because the cabin gets very hot in the summer, and tends to equalize.
In the winter, I have seen a similar temperature difference. The insulated side is on average 8 degrees warmer than the non-insulated side.
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086302-x
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086331-5o
The cold weather measurement method above:
  1. Heat the cabin to 70 degrees.
  2. Turn off climate control.
  3. Drive for about five minutes.
  4. Park and take measurements.
I turned off the heat to remove any unusual hot spots in the cabin from the heat blowing out of the vents.
The temperature of the outside of the truck when I did the above measurements was around 23 degrees.
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086360-96
Last night I finished insulating the roof entirely. It is cold, and I want to get the full benefit of the insulated roof.
By the way, I am considering putting another layer on. It would be very easy to do. The roll linked above is enough to put one layer on the roof.
Here are the installation pictures:
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086404-ma
Use a utility knife like the one below.
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086441-kt
Push the wrap up into the edges and use the utility knife to cut it to size (along the yellow line shown below).
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086503-1
The final insulated roof:
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086548-6m
Covered with the roof shade:
Rivian R1T R1S Insulate Your Glass Roof - Improve Comfort, Efficiency 1769358086598-6f
arbreg17
Das
Vancouver, WA
R1S Preorder
I live in the PNW so this seems like madness to me, as the more glass you can get on a roadtrip the better.
But for those that this is the right route for, looks like a good project and well organized 🍻 Nice work.
Sportstick
Southwest USA
2015 BMW 228i MSport, 2024 BMW X3 30i SDrive MSport, 2025 Porsche Macan
Nice work, but the real answer is a sunroof delete or added to the build only when desired as a standalone option. I don't even have to have a credit back for excluding it if it was standard. Just get rid of it and use a simple steel roof. We were very happy to be able to content my wife's Macan with everything she wanted and exclude the sunroof. We get to 120F in the summer in cloudless skies. A solid shade with zero light penetration is a second choice. I tried electrochromic sunroof tech in a BMW iX during the summer - fail - insufficient light/heat block. As I said a few months ago, this is a true failure of Rivian product planning not to even produce a solid shade accessory part for sale (as Volvo has just announced for the EX60), given all the other nonsense they brand and sell as merchandise. However, I do see that 3rd party vendors have stepped in.
Mathme
Los Altos, CA
High Tech
I wonder if it would make the glass too hot with reflecting it back and possibly damaged the glass. Just a thought.
I've heard stories of people shattering their glass in the summer by putting a wrap/tint on it.
One of the first things I did was install a quality ceramic tint on the side windows and front window (the lightest shade available on the front). This noticeably "helped" the AC cool and maintain cool in the summers -- even on 100+ days.
Singletracker
NV
2023 R1T QM w/20” A/T’s
I have an R1T. From the front seat perspective, the sunroof is virtually invisible. I agree that an option for a metal/composite roof would have been my choice, for sure. I don’t know why there is such a fascination with sunroofs that ultimately create an overheated and uncomfortable environment, and are prone to breakage. I would seriously consider an aftermarket replacement for the existing sunroof. How about a nice carbon fiber drop in?
Having said that, based on reports of sunroof breakage due to insulation mods, I’d be a little concerned about getting too carried away with them. But, maybe those reports are overstated. Who knows?
darkrystalR2
Kevin
Wisconsin, USA
2007 Ford Sportrac - I hope it lasts until I get my R1T !
I really wish they would have had a sunroof that opens as well as a drop rear window in the R1T - like my Sportrac had.
JacobAZ
Heber, AZ
2025 R1T dual large
With the glass roof my grandkids (ages 3 and 6) in the back seat, keep me updated on the status of the moon, clouds and aircraft. Of course, very important when driving.
Just Passing By
Bay Area
(Ancient Audi A6 gone) - 2 wheels-only for now Honda CB500X
I thought I read something on this forum about that. IIRC (which I may well not be so don't take my word for it!) adding a dark tint on the inside concentrates heat in the glass, whereas adding a wrap on the outside can/may reflect some heating effect before it gets to the glass. In any event, not something I'd want to risk without tracking down a definitive, non-AI answer.
I suspect what might exacerbate the issue in using dark tint, is that the roof can be close to 90 degrees to the strongest incident sunlight i.e. at midday. Side windows and windscreens etc don't have the same problem, both because super dark tints are often illegal, especially on windscreens, and all the glass surfaces are at significantly more oblique angles to the strongest midday sun versus roof glass.
Just my 2c of uninformed speculation.
lefkonj
Jeff
New Jersey
Gen2 R1S Tri, I4-m50
I would curious about the heat reflecting back to the glass and potentially causing an issue with the integrity on the glass and the seal over time. Interesting idea but I have concerns.
SteveInBend
Steve
Bend, Oregon
2022 El Cap R1T
I guess every little bit helps but my own simple measurement - hand near windshield vs hand near roof glass - says that you're going to get a lot more benefit from keeping heat heat from being lost/gained from insulating the windshield rather than the roof.
mkg3
R1S, Model 3, Outback, Artura
How do you insulate the windshield?
buddha2lotus
atlanta
model s
physician
I have both a ceramic tint and a sunshade on mine and knock on wood, no problems after two years. Without them, it was an oven in hot Georgia summers.
HaveBlue
I bought one that has reflective foil on the up side. If I roll down all the windows, the wind buffeting knocks it down. I need to figure better clips. It's no longer on Amazon.
SteveInBend
Steve
Bend, Oregon
2022 El Cap R1T
Obviously, you can't while driving. Just pointing out that you're not getting a lot of benefit from reducing heat transfer through the roof when most of it is through the windshield. Otherwise, I guess we'll have to wait for fully-autonomous driving 🙂
