Adaptive Cruise Control unavailable until serviced
gerrylum
Gerald
Providence Village
Director of Marketing
Good to know, thanks!
I’m using the fuse tap for power.
Did you also remove the AXM power connection if you're using the harness from Comma?
jbrumsey
Sterling, VA
Good call. I have not removed that connection. Certainly something to try next.
gerrylum
Gerald
Providence Village
Yeah, that can cause issues as well. Generally recommended to use either fusetap OR AXM power, but not both at the same time. Using both has the potential to send power feedback through both systems.
Rivian R1T R1S Adaptive Cruise Control unavailable until serviced 1779208285610-4l
jbrumsey
Sterling, VA
jbrumsey
Sterling, VA
I also need to check which fuse I’m tapped into. I think it may be F34 and if so can try moving over to F33 though that has never been a problem in the past.
gerrylum
Gerald
Providence Village
I’ll check the harness but looking back through the instructions it says that as of July ‘25 the Lukas harness is not using the AXM for power and is using the fuse tap. I bought my harness + fuse tap from Lukas in early July. https://docs.google.com/document/u/0/d/1clodGRssTx-dSPSUrQITq_vqumgWcpSUw83zdcAZR-A/mobilebasic
Ah, ok, you have a Lukas harness. That's a different story.
Yeah, that shouldn't make much of a difference in this situation. You're not pulling current from the AXM so fuse location isn't going to affect anything on the AXM itself.
So, possibiltiies are the harness itself is bad (unlikely) or it's just an unrelated problem with the AXM or a related module.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
Today I had this error when I had forgotten to put the Comma back into on-road mode. So the Comma was "half there" and seemed to lead to this. I parked, put it in on-road, and it was fine. This leads me to wonder if you may have a connection issue, particularly with the USB cables. Unfortunately that is hard to troubleshoot unless you have a couple of known good cables.
jbrumsey
Sterling, VA
Just to close the loop on this, last night I received the 2026.15.01 update and everything is back to normal now. Really appreciate both your help Gerry and Carlos!
