Battery Nerd Alert - R1T and Home Backup
doit82
Vermont
Model Y, R1T
Buy a charger, plug-in to truck outlets and connect to batteries in powerwall. Or is powerwall meant to be a specific proprietary product VS a generic term?
Tesla specific in combination with my solar with an integrated gateway.
zipzag
Chicago
Model Y
Here's the functionality that is missing from the solar inverter in the video:
"The MultiPlus-II will prevent overload of a limited AC source, such as a generator or shore power connection. First, battery charging will automatically be reduced when otherwise an overload would occur. The second level will boost the output of a generator or shore side supply with power taken from the battery."
https://www.victronenergy.com/inverters-chargers/multiplus-ii
GregEVs
Greg
Wisconsin
Sheet metal
My current home energy setup I wouldn't need 240V. I had done a setup similar to your suggestion with a Goal Zero power station (with 120V) and I can power my fridge, air handler, modem, TV and some lights. Even since I sold my GZ with my van I can still use the truck just as long as I don't connect the ground between the truck and my transfer switch.
Output would be <500W by my estimate so I could power those limited circuits for a week or more with a 70% SOC.
What I would like to known will there be a time that those that camp like boom docking will they every be able to charge their trailer/camper batteries with a charging point that charges EV
zipzag
Chicago
Model Y
You would need a very large trailer battery bank to benefit from DCFC fast charging. 15kWh of LFP house batteries could perhaps be charged at 7kw, which is level 2.
Engineering, Dog Petting
Ecoflow sells a J1772 adapter and I'm pretty sure I have seen other brands with an actual J1772 socket on them, I just can't think of what they were offhand. L2 EVSEs are very easy to make work with a normal battery charger.
zipzag
Chicago
Model Y
J1772 has a handshake, so that piece would be needed too.
jemkewl
There are two companies in Colorado that have promised / protoryped exactly that. I believe one is called teardrop Colorado. Cannot recall the other at the moment.
It's just a matter of two resistors and a diode to get a station to enable power. I have a cable I made with a j1772 inlet that activates a C13 plug immediately after being plugged in. Obviously the device that plugs into it isn't made aware of how much power/current is available, but if it's any kind of a standard station, it's going to exceed what you'd usually want to take from a C13. I use it for charging my e-bike battery, which is limited to ~350W.
