Charging w/portable battery?
JacobAZ
Heber, AZ
2025 R1T dual large
The 30A outlet on many of these units is a TT-30, which is just a 30A 120V outlet. With an adapter, plugged into the 14-50 on the mobile EVSE, thats going to be limited to a slightly fast L1 charge at 120V/16A. I've never tried it, but that is what I've read.
Correct that the 30 amp outlets on portable batteries are TT-30 and Rivian mobile charger needs a TT30 adaptor and a neutral ground bonding pulg. TT-30 is the standard for RV and campground 30 amp sockets. However, the output from the battery can be 120v/30 amp = 3.6kw per hour. There is no need to derate the charge amp on the Rivian, unless you want to. A battery will only output what it is capable of. The EVSE will negotiate with the battery to choose the charge amps. If your concerned about the TT-30 adapter overheating at 30 amps, you can set the Rivian to 24 amps (80%, and 2.88 kw per hour). Not sure what you read, but this is real world what I do.
BCondrey
Barry
Richmond, VA
I get that. The Rivian mobile EVSE itself has a limit on 120V charging I think. It's not that the human derates it, it is that the EVSE does. Even if you plug it into a 14-50, the EVSE is only going to "see" 120V, and limit it. See page 13 here: portable-charger-guide-en-us-fr-ca-101822.pdf
Actually, it is 12A, not 16A. There are other mobile EVSE that do 16A I'm thinking.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
I've charged as high as 32A with the Rivian EVSE. I have spent days with it running at 24A (lower for safety) and hours with it at 26A (being watched).
I use a home-made neutral bonding plug and this: https://a.co/d/0dwstpzF
Edit to add: I think you are confused and citing what happens if you put the NEMA 15P pigtail into the EVSE. With the 14-50 and the charging adapter, it won't limit itself.
Reactions: VSG
VSG
R1T LE/RB/OC/20
No, this is not correct.
No. What @JacobAZ says is correct. I charge my R1T at campgrounds from the TT-30 using the Rivian mobile connector and an EV specific TT-30 to 14-50 adapter. I have been doing this for 4 years.
The TT-30 can provide 30A @120V under these conditions, which you should dial back to 24A in the car to protect the wiring behind the outlet because this is a "continuous use” application.
BCondrey
Barry
Richmond, VA
That's good to know, thanks!
