Car unusable after being left for 7 days
Hilarious. If the Rivian BMS has problems keeping the 12V batteries charged, it will have the same problems with 48V batteries. The problem isn't the batteries or the battery voltage.
I'm looking forward to a company that tries just having every piece of equipment with a direct HV connection, and its own voltage step down circuit if it can't be run off HV. Having a secondary battery system that has to be independently managed is just weird and has caused a lot of issues. Issues that aren't avoided by changing the voltage of secondary energy storage.
And that would be inovative…
Supratachophobia
Ohio
S
Not sure about dying on a hill, but as an EE I have harped for a while that we need to bump the LV side voltage with the currents we are asking from modern vehicle systems. You know, p=va... there comes a point that if you don't boost the "v" variable the "a's" start becoming unwieldy.
A lithium 48v LV battery can withstand exponetially more abuse, draw-wise, than the 12 lead-acid MC batteries Rivian is using. The "keeping it charged" portion of the problem also get's easier. The system can count wh in & out, rather than monitoring voltage. Draw 50% from your 12v pb battery, and you are done; not going anywhere. Draw 50% from your 48v lithium LV battery, & it fires your vehicle up as it would at 100%... while making a note to add wome wh's to it.
Seems a good plan to me...
Certainly the 12v loads in the last 50 years have exponentially increased. For that reason, we can either stop cramming more low voltage stuff in or increase the V as you say.
Tim-in-CA
So Cal
Gen 1 R1S, Lucid Air, T-Bird
After 4 pages, the OP has yet to post any response or reply to ANY other threads. I'm calling this FUD and a fake post. Mods should just ban them at this point!
VSG
R1T LE/RB/OC/20
So your argument is really that lithium is a better battery chemistry than lead-acid for this application, as opposed to 48V is better than 12V. That's neither here nor there, because the problem with Rivian's 12V system has nothing to do with the chemistry or the voltage, so switching either doesn't fix the fact that the BMS has had bugs which allow the 12V batteries to fully drain, regardless of their chemistry.
R.I.P.
Sean
San Carlos, Mexico
Electrical Engineer
Nope. My argument, as i thought I clarified, is that the "a" is getting too big in the p=va equation. At some point you have to add some more "v" to keep the system balanced.
Oh... and yes, the pb batteries just make it worse.
You disagree, all good.
:cool:
LivingInKaos
R1T Launch Green Forest Edge
The issue here is if there is an issue that the vehicle needs to blow the HV fuse, the fire department needs to kill the HV, the shipping mode disconnects the HV, it kills the entire system.
Could you elaborate on why either of those situations would be an issue? Rivian's transport mode doesn't fully disable the HV battery anyway.
LivingInKaos
Say you have an accident that damages the HV battery. Would it be safer for the HV to control the contactor that disengages the HV or a separate voltage system that can fully function if the HV battery is compromised? It's a safety feature.
And problem solving like that is what makes it innovative. If they come up with a circuit with capacitors holding a charge in the event of a HV failure that could control the shutdown.
Innovation is solving known issues in new and creative ways.
You don't need the remainder of the electronics to be active for an extended period of time in that situation. The vehicle is undrivable when disconnecting the HV system as a significant portion of the electronics is disabled.
Retain window control, emergency lighting, and an SOS system and that's really all that's needed of the vehicle is at a stop.
ads75
Reading, Pennsylvania
Utilities
So your story scares me. Why did it have to sit there for 2.5 weeks until mobile service could replace the batteries. If my ICE 12v dies in my driveway, I’d have it sorted in a couple hours max. Did they have you try to jump it? And if that didn't work, cant we replace the batteries ourselves? I get warranty vs out of pocket, but at 2.5 weeks I’m going to try and figure it out out-of-pocket.
My R1T died in my driveway. Part of the reason why it may have taken 2.5 weeks to get a mobile appointment is I live 2.5 hours from the closest service centers (although my mobile tech lived about 1 hour 15 minutes from me). Rivian did not suggest or mention trying to jump it myself. I thought about trying, but decided not to. I do also have a 2019 Wrangler, so I wasn't without a vehicle. In my mind, if I did jump it or revive it on my own, how long would it last? Would it die again in my driveway, or at a store, or at work? I did not get a 12v system warning either, at least within the weeks before it happened. I remember getting one months ago, but it cleared before I backed out of my driveway.
I also believe, perhaps wrongly, if a problem isn't costing Rivian money, it won't be as high as a priority for fixing that issue. Its not to say someone should make it as expensive as you can for Rivian, but if I did revive my 12v system on my own, they would probably just close the ticket and move on. Meanwhile I would be wondering when it would die next. When it died it was during relatively mild weather in the summer in Pennsylvania. Maybe I am overthinking it, but if they have to do warranty work, they can see they have had X number of vehicles with a 12v battery failure in a period of time, maybe the software needs fixing/tweaking, maybe bad 12v batteries, maybe something else. FWIW, I updated my software about a week before my 12v died, one of the new features was reduced vampire drain. I do not know if it was related to my problem, if that was a cause I was in a very small minority of those that had a problem.
I think this thread may have set a new record for life after OP bailed. They pulled a one and done and it keeps plowing ahead.
While I have never had an undrivable vehicle, based on my experience, they don't seem to differentiate between vehicles that are in service where they are paying for a rental, and one where the owner opted not to do a rental. Both situations were unacceptably long.
ATL_R1S
Atlanta
'23 R1S Adventure
Alright, so after doing some reading it seems like steps needed to un-f**k yourself alone and off grid goes something like this:
1. Jump the primary battery from the hitch using a jump pack. You got to store that jump back in the frunk and you need to keep a tool in the hitch receiver to be able to get to the manual frunk release. Parts needed: Jump pack, torx driver and bit
2. You can now open the doors, but still cant drive. So you now need to try and charge the secondary battery. For that you need an additional charger. To save yourself off grid, parts needed - 12v charger and some way to power it (integrated or 2 devices). I have a small Jackery and a 5amp NOCO charger (that will charge from 0volts) that I think can do the trick combined.
3. Your 12v batteries wont charger (seems unlikely) then you resort to getting a ride to an auto parts store and pickup 2-batteries as close to spec as possible. Can always get the OEM replaced from Rivian later.
4. That fails, Tow truck
So seems like if I’m going off-grid or a long road trip I should keep some extra stuff in the frunk.
How does that sound?
Since my build is newer and has a single 12v instead of two, my plan is a bit simpler, but yes that sounds like a good plan if you have and earlier build with two 12v. Except for step 3, I was told by a Rivian tech that if they're dead enough to be below 12.5v then they will not accept a charge and allow driving after being jumped. I believe spring '23 is when they switched to a single 12v instead of two. Mine would not require two jumper packs/chargers, in theory.
