picklebill
- Thread starter
- #1
Hi All -
Relatively new Rivian R1S owner here.
I come from driving a Tesla for the last 7 years.
My R1S is equipped with the 20" AT Dark wheels. According to Rivian that configuration has a range of 289 miles. I have not yet charged it to 100%, but at 85% it shows 239, which works out to 281 at 100%.
In my Tesla, it seemed that the "rated" range on the dash was just a straight conversion from battery percentage or kWh remaining. They had a "reference" consumption of 300 Wh/m or whatever, so regardless of weather or past range, that's the number that was displayed. If you were using the nav, it would make adjustments to that to predict your arrival state of charge, but the range on the dash was always that "rated" number.
Do Rivians work the same? Does the "rated" range on the dash take into account wheel configuration? Weather? Past use? The charging screen in the vehicle seems to suggest that it uses past data to calculate, and if my range is 281 at 100% I sure hope it's assuming the AT tires.
Thanks for any input you have!
