Driver Side Rear Quarter Panel Window Exploded
tate16t
Robert
2023 El Cap Granite R1S
Car Enthusiast
My Tesla glass roof developed a crack across from one side to the other. Tesla was unable to identify any external impact and replaced the entire glass roof panel at no cost to me. The work order stated the crack was created due to stress.
electruck
Dallas, TX
2023 Rivian R1S
This is a fallacy many people fall into. Just because something costs a lot or that its very expensive, expectations against mishaps are somehow it should be protected.
Regardless of the cost of the vehicle, window should not explode just because there is a temperature gradient between the inside and the outside. While pressure is a function of temperature, along with density, the robustness of the glass should tolerate this condition, since its tempered and has a safety factor built into the glass.
The edges with circle most likely happened as the result of the blow out, just the same as the cracks along the door frame on the right hand side of the picture.
Often times, these service advisors are taught to question and deny claims without any expertise. The glass should be replaced and analyzed for factory defect by the glass manufacturer to prevent future occurrence, worse against potential injuries from glass fragments. A potential recall subject.
Regardless if the vehicle costs $30K or $300K it should not happen and be covered if the vehicle is within the warranty period.
un-damaged glass will tolerate normal temperature and pressure gradients. but, once damaged, even a small chip creates a stress concentration and frequently leads to material failure.
mkg3
R1S, Model 3, Outback, Artura
This is true for non-auto tempered glass. There are DOT regulatory standards that require glass not to fail even with a small chip. That's what the safety factors and the laminate tolerances ae for.
It is expected to withstand small foreign object debris damage.
electruck
Dallas, TX
2023 Rivian R1S
it's actually true for all tempered glass which is intentionally used for side and rear windows precisely because tempered glass shatters into small pieces which reduces injury (tempered glass is much stronger than un-tempered glass but still far from impervious to damage). the DOT requires laminated safety glass for the front windshield to ensure high impact resistance and safe shattering.
damage, even to tempered glass, causes a stress concentration which can lead to the type of failure experienced by the OP.
Robot Overlord
Northern Virginia
I was stationed in Riyadh, Saudi Arabia for a year 2003-2004. Out summer temps were frequently over 105F. Many of us drove new Chevy Tahoes and we had to leave the windows cracked open to vent them to prevent exploding windows - which did happen on some of our hottest days if left buttoned up in the brutal sun.
Greg Chick
Greg
Tehachapi Ca. 93561
diyplumbingadvice.com
Retired Plumbing Contractor
When I liv ed in Az. I left windows open as well. Wise regional knowledge.
CampfireWisdom
Greg
Rancho Cucamonga, CA
www.campfirewisdompodcast.com
2014 Toyota Prius C, 2018 Subaru Forester
Teacher
I’m no expert, but something clearly damaged the window prior to the event. I would not have even asked Rivian to cover that. Come on, man… QQ
DogPound
Long Island, NY
FAA
I have had a ford explorer sunroof that was closed, while driving down a highway explode outward. Sometime glass has an internal flaw, frame is tweaked, or acts of random gremlins. Too bad that Rivian didn't do you right since it's a month old truck, but insurance is there for a reason. I have two R1's (22 T, 23 S) and twin 14yo boys. They slam the doors like they are trying to kill something all the time and no exploding glass yet. Hope it works out in the end.
Dave Cundiff
Dave
Pacific County, Washington
As a SME myself in a different industry I find it easy to accept other industry consensus based expert opinions. Get one, that will end the non expert opinions.
SME = Subject Matter Expert?
Thanks, @Greg Chick, for your contributions to this forum!
Greg Chick
Greg
Tehachapi Ca. 93561
Yes, another is, "IE", Industry Expert", simililar but different. The AHJ has criteria for the threshold and the AHJ is, Authority Having Jursdiction. Often the AHJ is the State, like in my case, they have paid me as such. Sometimes the City is the AHJ, but if it is Fire Related, the State Fire Marshal rules. My area is / was not automotive, but the pecking order is similiar.
Dave Cundiff
Dave
Fascinating! DM sent. Thanks!
lefkonj
Jeff
New Jersey
Gen2 R1S Tri, I4-m50
My teenage sons always slam the doors never seen this happen before very interesting.
electruck
Dallas, TX
2023 Rivian R1S
that's because slamming the door isn't the root cause.
crashmtb
Man oh Manitoba
It's important to consult the AHJ's SME for the correct TLA or there will be a SNAFU PDQ
