EVSE recommendations sought
Yossarian
Yossarian
SE Pennsylvania
Update: While I was leaning toward the Grizzl-E, after some additional research, I decided to order the Emporia.
Bth units get good reviews, but I plan to hardwire the EVSE, and the Emporia has the edge in that as wiring can be connected directly to the bus. The power connection in the Grizzl-E is designed to be used with lugs, which is fine, but apparently the connections are small, and most lugs sized for 6 AWG will not fit, forcing you to either grind them down (not recommended) or finding ones that wll fit.
Again, thanks to all for the advice.
