Portable Charger Recommendations
TexasCrane
Austin, TX
'26 Quad R1T, '24 Ineos Grenadier
Since Rivian is no longer including a portable charger in 2026 vehicles, what's the current thinking on the best portable charging solution?
The Rivian charger is $400 in the gear shop. Tesla sells theirs for $300 and they can be found cheaper on eBay. Both of those can do 32 amps. Lectron sells a 40 amp charger for $270. Grizzl-e sells their mini 40 amp for $479, but that also includes a set of adapters as well.
The original portable Rivian charger did what I needed it to do in my 2022. I mostly used it to plug into a welding 10-50 outlet (with an adapter) when at my ranch. Just wondering if there's a consensus on the best portable charging solution these days. Thanks.
beatle
Springfield, VA
Tesla UMC. It has the most native adapters available to plug into a variety of receptacles, is reasonably priced (plenty used) and is very reliable.
Scottm
Eugene, OR
Toyota 4Runner, Tesla Model Y
physician
Second this. We already had a bunch of adapters for our model Y, so it’s way more versatile than the Rivian mobile EVSE.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
They're all about the same in the grand scheme. Some have extra features. I have a Godiag $125 EVSE for my motorcycle which would be my top choice. It has a display and is configurable, which I find useful if I'm connecting to a limited-power outlet. For example I just used a generator to charge, and the Rivian adapter always went to 32a, choking the generator. Luckily it would later recover once I got in the car and reduced the power to 24a. If I had used the Godiag, I could pre-set it to not do this. If this had been an outlet with a breaker, I might have to reset the breaker and fight to change settings quickly.
