Front License Plate Mount Options for the Rivian R2
EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
Rivian R1T, Tesla Model 3, & Model Y
3D-Printing
The Rivian R2 has one of the cleanest front ends on the road and mounting a front license plate is the quickest way to spoil it. That clean look is a big part of why so many Rivian owners skip the front plate altogether. But if you live in one of the more than half of U.S. states that require a front plate, running one isn't really optional and Rivian's factory bracket makes you drill permanent holes into your brand-new bumper to do it. The good news is you have cleaner, fully-reversible options. Here's the dilemma and the two best ways around it.
The problem with the factory plate mount
Rivian does include a front license plate bracket with the R2, but installing it means drilling holes directly into your front bumper. That's permanent, irreversible damage to a brand-new vehicle: you can't undo it, it can hurt resale value, and it leaves you committed to a plate location you may not love. For a vehicle with a front end this clean, putting a drill to the bumper is a tough ask.
The good news is you don't have to. There are purpose-built, fitment-specific mounts for the R2 that keep you road-legal with zero drilling and they're fully reversible. Below are the two approaches and how to choose between them.
Option 1: The SnapPlate (Clean, Removable, No Drilling)
The SnapPlate Front License Plate Mount for the Rivian R2 is our flagship solution and the one most owners reach for. It's engineered specifically for the R2's front end, so it sits flush and blends into the fascia rather than hanging off it, all without touching a drill.
Rivian R1T R1S Front License Plate Mount Options for the Rivian R2 SnapPlate for 2026 Rivian R2 Main Fad
What makes the SnapPlate stand out:
  • No drilling, ever. The mount attaches without modifying your bumper, so there's nothing to undo and nothing to regret at trade-in time.
  • Snaps on and off in seconds. Headed to a car show, a photo shoot, or a state that doesn't require a front plate? Pop it off and the front end is completely clean.
  • Removable only if you want it to be. It's tool-free to pop on and off, but it also ships with anti-theft T25 security screws and a matching driver, so you can lock the plate (and the mount itself) to the vehicle to deter theft.
  • Adjustable height. The SnapPlate mounts at multiple heights, so you can dial in the look you want, from a high, flush-to-the-fascia position to a lower placement that keeps the plate out of your 360-degree camera view.
  • Designed to disappear. The low-profile, minimal design is built to match the Rivian aesthetic instead of fighting it.
The SnapPlate attaches to the R2's plastic front grille, and it's engineered with that in mind: the mount is designed to break away before the grille does, protecting your vehicle if the plate ever takes a hard hit. The main thing to keep in mind is car washes. Touchless washes are generally fine, but a brush-style (touch) wash will grab the plate and pull until something gives, so it's best to remove the SnapPlate before a touch car wash. Since it pops off in seconds, this takes only a moment, and it's the safest way to protect both the mount and your grille.
For most R2 owners who want a permanent-feeling solution that's still fully reversible, the SnapPlate is the easy recommendation.
Option 2: The Tow Hook Mount (A High-Strength Alternative)
If you'd rather anchor your plate to an existing hard point, the Tow Hook Front License Plate Mount for the Rivian R2 is a stainless steel screw-clamp design that secures to the vehicle's front tow point, with no drilling required. It's a simple, sturdy option for owners who want a mount that ties into existing hardware.
Rivian R1T R1S Front License Plate Mount Options for the Rivian R2 Tow Hook Mount for 2026 Rivian R2 w Acc Main Fad
Because it clamps to a solid metal tow hook rather than the plastic grille, the tow hook mount is built for maximum strength. That makes it the more robust, leave-it-on choice, including through car washes, where its secure anchor and rigid stainless construction stand up to brushes and high-pressure spray without the need to remove it first.
About the front bumper camera
One thing R2 owners ask about is the front camera and whether a front plate gets in the way. The good news: your standard front camera view stays completely unobstructed no matter how you run the SnapPlate, so the view you rely on most while driving is always clear.
The only place a front plate can show up is the 360-degree (top-down) camera view. Mounted in the high position, the SnapPlate sits cleanest against the fascia and appears in the 360 view to a degree comparable to the factory bracket. Drop it to the center or lower position and it clears the 360 view as well. You decide where to land on that spectrum between the most integrated look and the cleanest top-down image, and because the mount comes off in seconds, you can always remove it entirely whenever you want.
Rivian R1T R1S Front License Plate Mount Options for the Rivian R2 SnapPlate_for_2026_Rivian_R2_Camera_View
Which one should you choose?
Both keep you legal without permanent modifications, so it comes down to preference:
  • Choose the SnapPlate if you want the cleanest, OEM-style, centered look, the fastest on/off, and height adjustability to keep the plate out of your 360 camera view. Just plan to pop it off before touch car washes.
  • Choose the Tow Hook Mount if you want maximum strength and a leave-it-on mount that anchors to a solid metal tow hook and handles car washes without removal.
Either way, you'll get a fitment-specific, no-drill mount built for the R2, so you stay road-legal without permanently altering your bumper or settling for a plate position you're stuck with.
Ready to gear up your R2?
Browse the R2 SnapPlate to get rolling today, or grab the Tow Hook Mount if you'd prefer that route. Both are designed and tested specifically for the Rivian R2, so you can stay road-legal without drilling into your bumper and pick the balance of clean looks and clear camera view that works best for you.
Michael
Michael
Range Rover / Jeep Grand Cherokee
In California and other states, you can use a vinyl plate the sticks to the front bumper, no bracket, no screws, just peel and stick.
EveryAmp
EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
3D-Printing
This is true for California if you are ok with a long term sticker on your bumper and installed off center since there's a camera dead center of the bumper. Cutting a hole in the sticker would put you right back at risk of a ticket for violating California Vehicle Code § 4464, so might as well just not have a plate at that point.
Great thing is there's options for everyone's taste and preferences!
RivianPL
Pleasanton
2025 R1S Tri
I live in the Bay Area and 90% of Tesla’s don’t have front license plates. I have an R1S and decided to forgo the front plate. Haven’t had any issue in over a year and given the number of others without a front plate I suspect the enforcement of the front license in CA is pretty minimal.
EveryAmp
EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
3D-Printing
Congrats, we'll be here for you if you ever need us! 👍
Michael
Michael
Michael
Michael
I have a R1S Gen 1. My camera is directly above the bumper. No issues.
EveryAmp
EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
3D-Printing
This thread is for the R2. Thanks for the bumps though!
Zathras
Carlsbad, CA
Subaru Crosstrek Plug-in Hybrid
Just ordered my Tow Hook Mount version. Got the 10 percent discount too! No question the Tow Hook version is the better deal. Plus being the more robust version. And I won't even have my R2 until early 2027!
freshpow
FYI for CO owners, I have run my R1T without a front plate for 3+ years without issue. That said, I do have the SnapPlate (great product!) and keep it in my frunk. Will only slap it on if I'm street parking in/around Denver because I've heard the meter maids like to ticket for missing front plates.
EveryAmp
EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
3D-Printing
There when you need it, gone when you don't!
This is the way. 🤙🏼
chaynes745
Colorado Springs, CO
Thanks for the 'warning' about street parking in Denver. I have been sans-Front plate for the 3.5 years with my R1T, and have only had a front plate option on 1 vehicle in the past, albeit with a quick removing mount on a winch fairlead. No plans to run a front plate on my R2, but may opt for the tow hook mount just in case.
