Garage door opener not working intermittently
suprteck
suprteck
Anthony
Tesla Model 3, Rivian R1T
Mechanic
I have a mobile appointment next month but I doubt they will find anything to fix it.
Have same issue. Quick tap, long tap, near, far, any combination… at best I get a 50% success rate. Soon happens so it registered the press, just doesn’t do anything. . I’ve resorted to keeping a remote opener in the car. If it fails to work I tap the regular opener and it instantly works. Definitely a rivian problem.
My suggestion is just do 1 quick tap and wait.
When it first came out I was holding it too long or being impatient and pressing a second time. Once I started doing one quick tap and waiting, it has worked 100% of the time. Sometimes it might be 2 or 3 seconds before the garage starts moving but is working every time.
Mathme
Los Altos, CA
High Tech
I’ve found one quick and complete tap does it for me. It also takes 4ish seconds before the door opens.
tk21
Military
Just started happening to me - .38 SW build
irfan
Ohio
Range Rover
I have definitely tried that as regularly well. Same intermittent result.
Gkfisher
R1s
Just started with me after the .42.1 build (updated last night). Wondering if I need to reprogram. That will be the next step.
topracer
MD
2023 Rivian R1S
I also have this intermittent garage door opener issue. It is a Genie opener. Seems to fail more often leaving the house (closing), and fail less on coming home (opening). Already tried to pair again, and still didn't fix the issue.
