Home lifts that work?!
Engineering, Dog Petting
if only there was a factor of safety in these sorts of things
I design all my stuff with a 1.0001 safety factor
crashmtb
Man oh Manitoba
electruck
Dallas, TX
2023 Rivian R1S
camaroz1985
Carlisle, PA
R1T, ID.4
But they didn't lift that weight they just showed it supported it and the jack was locked in the up position. Most issues happen when lifting or lower weight.
This is true, but you will notice the 5000 lb jacks lifted 5320 lbs without issue, and you (hopefully) won't be under your truck while you are lifting or lowering.
That's right they work at 7000 lb, but 7000.1, complete disaster.
Ok, maybe that last statement is true if Dark-Fx works on them. Let's all remember this comment when he tries to bring a product to market ;)
Mark_AZR1T
Gilbert, AZ
jackpucks.com
R1T Launch, R1S Canyon Red
I wouldn't have any problem using a 7K QJ on my Rivian, zero. Issue is, they don't fit our vehicles in either direction, including the extended version. However, the new EV version 3 Ton rating looks like it would fit....but at $2K, sorry.
I own a QJ for my ICE vehicles and it isn't even close enough in length to fit.......
Iatros786
Iatros786
Floriduh
74 Vette, 997TT, Q7
Wow thanks for the deep dive everyone on QJ!
Anyone have a recommendation for a good 2 post lift at home that they've used on their Rivian?
atebit
R1T, Porsche Boxster
Bendpack (the same company that makes QJ) was a range of 2-post lifts. You need a fairly high ceiling to accommodate the posts (not to mention the roof of the car you’re lifting. :)
At least for me (and I think for all EVs going forward) I see less of a need for the home mechanic to have to be able to walk around underneath the car. Just raising it up enough to get the wheels off the ground, or raise the car to a more comfortable height is probably all that’s needed. Something that could retract relatively flat so you could mount it in place and leave it.
I had originally planned to just move the two QJ lifts together in the center of my garage bay when I wasn’t using them. But the hoses & connectors were IMHO too delicate for that and I didn’t want ATF stains all over my garage floor. So I took to hanging then against the wall with the bottom resting on the floor. They were still heavy AF to move around and get lined up with the jack points & parallel to each other. Which is why I ended up unloading it. Clearly, most people that have one love it, so it’s probably just me. Maybe the 5000 is a lot lighter/easier to maneuver.
Harbor Freight is rumored to use a 50% safety factor - plus or minus.
crashmtb
Man oh Manitoba
Tucker74
Tucker
Austin, TX
I was wondering this too, all the things I primarily do needing lift access aren’t needed on the Rivian (I’ve restored 6-7 vintage Land Cruisers). Only thing I could see would be brakes/suspension/axle shaft, what’s your use case? Seems overkill for rotating/swapping tires …
madgrey
Allan
Fidalgo Island, WA
2026 R1T, 2016 Miata, 2015 Viper
Hardware Design Verification
Iatros786
Iatros786
Floriduh
74 Vette, 997TT, Q7
I've got a 74 vette I restored years ago with my dad and it was a great way to spend quality time with your kids.
So I was going to pick up another car (from the 90s with any kind of safety equipment lol) and spend time with my kids on it since they are showing some interest.
I have the rare opportunity to be designing my garage too, so wanted a lift I could easily use with the Rivian as well for small maintenance and detailing for.
strykerwsu
Kansas
I have the 7000, about a 100 lbs each. Sucked until I finally made myself get in shape. Now not bad at all. I use the wall holders and stay nicely out of way and have rolling cainet for the main hydraulic pump so works great for me. Also got for about a $1k back on Black Friday in 2019 so convinced me to make the plunge.
Tucker74
Tucker
Austin, TX
Makes more sense, just didn’t see you replacing a clutch or welding up an exhaust on the Rivian ?
Iatros786
Iatros786
Floriduh
74 Vette, 997TT, Q7
LOL.. true!
I'd get my Rivian card taken away by a mob of granola-chewing, Patagonia-wearing Yetis..
Like this exhaust should :CWL:
Rivian R1T R1S Home lifts that work?! Rivian
