elektrode
Bran
NC
Honda Ridgeline to R1T
i have much less miles but i cannot get above 1.87 to save my life. wtf.
Same. Nearly 6k miles and I’m around 1.85mi/kWh
Lots of shorts trips. But no where near the same ballpark as theses hypermiling heros.
21” no aero
kizamybute'
21” no aero
That's pretty low for 21" wheels/tires. But, if you sit in the truck with it on, the trip meter counts that time and figure plummets. Or, if you're in a cold environment, then probably about right. With my 21's in CA and moderate temps, averaged around 2.3-2.5 miles per wh. No aero covers
Mark_AZR1T
Gilbert, AZ
jackpucks.com
R1T Launch, R1S Canyon Red
22,000+ miles! 2.2m/kWh.
Great thread....I'm surprised I'm at 2.2 with 20" AT's and the last 4,000 miles I've been on Cooper Discover AT3 XLT (heavy duty AT's). Mixture driving, including road trips and twice towing a car hauler. I do run the Coopers at 62psi +/- 2psi. They are rated to 80psi.
Rivian R1T R1S Just passed 10k miles. 2.44m/KWh consumption so far (on 21" wheels) 20230127_175557
Rivian R1T R1S Just passed 10k miles. 2.44m/KWh consumption so far (on 21" wheels) IMG_0266
Rivian R1T R1S Just passed 10k miles. 2.44m/KWh consumption so far (on 21" wheels) IMG_0267
Rivian R1T R1S Just passed 10k miles. 2.44m/KWh consumption so far (on 21" wheels) 20221222_135928 (1)
SlaterGS
Ohio
If sitting in the car counts negatively towards your efficiency, does that mean preheating or preconditioning your vehicle before entry is as well?
wondering if some of you with lower efficiency do more of either of those and that’s impacting the overall even though actual driving efficiency may be closer. 🤷‍♂️
Biturbowned
MD
‘20 Model Y, ‘22 R1T
This is very similar to me at 1.87 mi/kWh with 1134 miles on the clock, also with 21’s. Pretty mild winter here in the mid-Atlantic this winter. Average speed 27 mph.
SolartoEV
Western NY
Do you live where it's cold?
Thedude
Must be nice. Lots of towing, parking outside in the cold and short trips for me with 20” wheels.
Rivian R1T R1S Just passed 10k miles. 2.44m/KWh consumption so far (on 21" wheels) 42F3B16F-BDBB-444B-9E3F-DEA13F527D7F
goldburger
the service center gave me a loaner LE on 20” wheels with just under 8k miles and had a lifetime efficiency of 2.2 and in the three days I had it I had 2.4… and I drove as I do my regular truck. So it’s super baffling.
duessell
Syracuse, NY
R1T and Chrysler Pacifica PHEV
The numbers reported in the trip meter (which I reset when I left my house at 70% state of charge) are not consistent. See my math below.
Also note that the OP (@NC-Rivian ) screen shot is also weird because 10,027.4 miles/3,727.2 kWh = 2.68 miles/kWh, not 2.44 miles/kWh as the trip meter showed. Others are off as well. I believe the miles are accurate (they're regulated and numbers for my trip A match the distance). I suspect the trip meter is not showing accurate energy information.
See calcs for others below my screenshot. @SolartoEV, @goldburger, @AllInev, @Mark_AZR1T, and @Thedude.
My estimates.
Rivian R1T R1S Just passed 10k miles. 2.44m/KWh consumption so far (on 21" wheels) 1675019480214
Rivian R1T R1S Just passed 10k miles. 2.44m/KWh consumption so far (on 21" wheels) 1675018659864
Rivian R1T R1S Just passed 10k miles. 2.44m/KWh consumption so far (on 21" wheels) 1675021723951
goldburger
My estimates.
Ya I believe the total energy used being wrong is known but people say the efficiency is correct.
WSea
Patrick
West seattle
R1T, Outback
Architect
My loaner on 20s with 1900 miles had lifetime of 4.0! Had to be wrong. I’m only getting 1.8 In it.
duessell
Syracuse, NY
The Rivian app reported 16.0 kWh delivered to get me back up to 70%. Given the squishiness in the state of charge estimates, that' does get pretty close to the trip meter reported efficiency (1.69 vs 1.66). I know there are some losses in charging but, FWIW, my JuiceBox reported delivering 18.28 kWh for the same session.
Kitsap, WA
Presumably @Mark_AZR1T is in Phoenix area, not known as a cool climate. I was getting similar range, 2.1-2.4, in the summer
Rivian R1T R1S Just passed 10k miles. 2.44m/KWh consumption so far (on 21" wheels) Screenshot_20230129-171102
I watched my truck lose 5% in as many minutes right after I left the cabin today (mainly downhill), then leveled out. I notice this most mornings. It's got to be a battery conditioning issue that could be solved with pre-conditioning.
As I said before, we'll still be consuming that much power but it would be nice to have it happen while plugged in, and not during our driving.
Thedude
I’ve had good luck avoiding that drop by starting the truck charging for a bit before leaving. Set the charge limit to 70/85 and then up it to 85/100 before leaving and let the battery warm up by charging for a bit. I do it every Sunday for my weekly charge and it seems to help.
Kitsap, WA
I've tried that and it usually helps, but it's unknown how long it takes to really impact it. I thought I got it right today with 10 minutes, but alas, it dropped on me.
