PhatDaddy
- First Name
- Jim
- Joined
- Apr 11, 2023
- Threads
- 8
- Messages
- 411
- Reaction score
- 405
- Location
- Coastal Central Florida
- Vehicles
- 2025 G2 R1T El Cap PDM; (RIP: 2024 G1 R1T RC PDM)
- Occupation
- Retired IT
Thanks! Really appreciate the feedback!I don’t have any firsthand experience with the OEM cover, but I’ll do my best here.
No, there’s no mechanism to lock in a position along the rails. Our tonneau is designed to be as simple as possible, which could be a double edged sword depending how you look at it. There's nothing to break, but it doesn't have that feature. In the year since I've made my first tonneau, I've needed to drive with a panel or two out twice. Those two time I just wedged a small piece of cardboard or plastic under the cover in the rail and it stayed put with no issue. Not the most glamorous solution, but it works. As long as the tailgate is closed, you can remove as many panels as needed.
In regards to the plastic end pieces and strength, I can confidently say ours is much more robust. the ends of our covers are solid 1/2" thick UHMW (real tough fancy plastic) and the aluminum is a thicker, double walled extrusion. It can most definitely support your weight whenever you need it to.
It is made of aluminum, so if you bash it with a hammer it will dent, but I'd be really surprised if you could break it even if you were trying.
(Edit: ordered 01/27)
