mudito
Just went back and check my mobile charger. You are 100% correct. The mobile is 32A onlyI think the mobile charger only goes to 32Amps
Thanks. When attached it says 33 Amps. Your right the Nema says it can only do 32 Amps so must be a +/- variance there.That indicates you might have charged at 32amps. With your Nema 14-50 and Rivian mobile charger, you should be able to get 40Amps top (equals to 9.6kW), so that same charging session (66.5kw) should've have taken roughly 7hrs.
From the menu where you took that screenshot, check the BOTTOM RIGHT option when your charger is connected, and see if you can up the AMPS to 40A.
