R1S Electrical Plug and limits
Litup
Bend, Oregon
R1S Toyota Tundra 21
Portfolio Management
First I have to say I do love this forum. Very helpful in so many ways...
I haven't seen anything on this topic and after speaking to RIVIAN they didn't have much confidence in their answer so hear goes.. This winter I plan on doing a bit of back country skiing that will take me pretty deep in the forest at times.. Cold mornings and crisp afternoons so how much load can I put on the plug? looking to rough it and plug in an electric blanket! A coffee maker... and an electric stove to cook..
I could and must likely will do this in my driveway prior but would sure like to hear others experiences, battery drain, potential for overloading.... etc etc... In my home if I pull too much the breaker will stop further use... I can always to flip it back..
Out and about what would happen if I pulled too much? blow a fuse and what else might that be associated with? Would really like to know in advance as being stuck out in the middle of nowhere might be undesirable..
Thanks for any response and look forward to hear your successes and what concerns you fell I could have..
Thanks!!!
zefram47
Rivian R1T, Alfa Romeo 4C
Thanks!!!
The manual states 1500 W max on the 120V outlets.
jjswan33
Joshua
Sandy, OR
Running a space heater overnight in cold temps in my camper shell costs me about 5% battery, other cooking loads etc will be negligible for the most part. Now that I have my camper shell doing much more of the same this winter, if you look for me you will probably see me at the snoparks down the hill sometime this winter.
Outlet can output 1500W. In your scenario an electric blanket uses about 100W (probably less on average over time), most electric stoves don't use much more than 1500W but some do in the highest settings.
Litup
Litup
Bend, Oregon
Awesome .... thanks for the reply... I'll have to camp in my driveway and see how much I can use and the drain.... but sounds great!
I'll keep my eye out for ya!
Dgephri
Jeff
Portland, OR
Toyota FJ Cruiser
Finance-Real Estate
When I asked support chat about per outlet vs total draw they were very direct: don't exceed 1500w in any combination. One appliance in one outlet or across multiple outlets. Extension cords can add resistance, or a power strip can add more outlets.
Two AC outlets on the platform doesn't mean 3000w possible. 1500w total.
Your driveway test is the right thing to do.
Redmond Chad
Redmond, WA
I agree that the driveway test is important! For example, in June shortly after taking delivery of my R1S, I tried a driveway test and discovered that the 120V outlets in my vehicle wouldn't even turn on.
It took 4.5 months to get a service appointment. It is currently in for that appointment...they've had it for almost two weeks now, and I'm still not sure when I'm going to get it back. Or if it will work when I get it.
So yeah, try it first! :)
Electrified Outdoors
Mount Airy, Maryland
EVoutdoors.org
Real Estate
get a killawatt to measure how much your stuff is drawing. I wouldn't max it out at 1500w. I would want to make sure I am drawing no more than 1400 to be safe.
https://amzn.to/3QuC47e
SSpearsAU
Central Florida
2025 R1S
As Hurricane Milton approaches, I plan to need use of the Rivian for temporary power. In effort to extend the battery as long as possible, is there any advice on using the outlets and turning all other power draws from the vehicle off.
I think the way to do this would be in the settings to set the timer to remain on for as long as I need it. And once set up, locking the vehicle to turn off the other functionality of the car as to not use the battery unnecessarily.
Am I thinking through that right?
