ksurfier
- Thread starter
- #136
Holy smokes…just crank up your brain cell for a single GD moment and realize the variables at play!
Best estimate
346 miles in warm, high-altitude Colorado translates to approximately 300–310 miles at 70 mph, sea level, and 70°F.
Using 305 miles as the midpoint:
* Reported Colorado efficiency: approximately 2.45 mi/kWh
* Sea-level normalized efficiency: approximately 2.15–2.20 mi/kWh
* Range reduction: approximately 11–14%
* Central normalized range: ~305 miles
The temperature adjustment itself is probably small. Moving from very warm weather to 70°F may slightly reduce battery/drivetrain efficiency, but it also reduces air-conditioning demand. The higher sea-level air density is the dominant correction.
Using the reported ~346-mile result from Out of Spec’s standardized 70-mph test as the starting point, a reasonable sea-level normalization is possible. The original test was performed in northern Colorado, and Out of Spec identifies it as a standardized 70-mph highway test.
Approximate normalization
Assumptions:
* Test elevation: approximately 5,000 ft
* Test temperature: roughly 80–90°F
* Normalized condition: sea level, 70°F
* Approximately 60–70% of the R1S’s 70-mph road load is aerodynamic
* Calm wind and no meaningful net elevation change
* Same tires, vehicle settings, and usable battery capacity
At 5,000 ft and warm temperatures, air density would be roughly 20–25% lower than at sea level and 70°F. Only the aerodynamic portion of consumption changes by that full amount; rolling resistance and drivetrain loads remain broadly similar.
Best estimate
Assumptions:
