Setting up gearguard drivecam with new usb drive
RivAW
Alex
MA
I’ve been unable to setup a new usb drive to record gear guard drivecam but the car does not recognize any usb-c memory drive. I’ve followed the instructions that many have posted online (format fat32, create gear guard folder etc) and bought multiple different branded 256gb usb drives but the car doesn’t register when I plug it in. Does anyone else have this problem? What’s the solution?
Have you tried following the instructions in the owners manual? Including the specifics for a compatible drive?
Cortles
Cortles
Corey
New Jersey
Analyst
Yes. And I’ve also tried every combination of advice from actual users in this forum who have successfully connected at USB-C drive. So it’s now over to Rivian support to solve.
Leon
Leon
R1v1@n2024
I wasted a couple hundred dollars trying to find a workable usb drive. I finally consulted my geek brother for guidance. He informed me that only flash drives with a certain processing speed would be compatible. He also explained that some solid state drives would work, but be destroyed by the way they have to process the files to play them back. Here is what I bought per his specs. It connected, formatted, and worked the first time, and has been great and fast so far. Rivian should have included this equipment, or provided much more guidance, as it is too technical for an average customer. I bought an angular plug and an adapter with a short cable as well, so it can lay out of the way. Good luck. It is a nice feature when you get it working.
Limited-time deal: MOVE SPEED 1TB USB C Flash Drive, 1000MB/s Read Write Speed, USB 3.2 Gen2+Type C Dual Interface SSD USB Drive with Keychain Leather Case Thumb Drive for iPhone 15 Series/MacBook/Android Phone etc https://a.co/d/059f07sC
USB 4 Extension Cable 240W 1FT, Right Angle Thunderbolt 4/3 & USB C Male to Female Cable, PD 3.1 Fast Charging 40Gbps 8K@60Hz Video, Type C Extender Cord, for MacBook,iPad Pro/Air,Galaxy S24 S23 https://a.co/d/0aj677B3
Thanks for this write up. I bought this set up and just installed it with no issues.
LNL_HUTZ
Gene
San Francisco
2024 R1T Quad; Tesla MYP
Just to add another option, I had several unsuccessful attempts at formatting a suitable external drive and was finally able to make it work with a MOVE SPEED 256GB flash drive from Amazon. On Prime Day, it’s less than $40 right now. I like that it has USB-C and USB-A and the Rivian seems to work with it just fine. Of course, time will tell how it holds up. Also, I don’t have to worry about the interior getting to 150 degrees in the sun where I live.
I did add a $10 six-inch right-angle USB-C extension cord so the drive isn’t sticking out.
spievak
Jason
Santa Barbara, CA
2025 R1S Tri
Venture Capital
I bought exactly those items, and it all works perfectly. Thanks!
