Electrified Outdoors
- First Name
- Ken
- Joined
- Jan 30, 2023
- Threads
- 64
- Messages
- 3,684
- Reaction score
- 3,983
- Location
- Mount Airy, Maryland
- Vehicles
- 2026 S Tri Max, 2024 Silverado EV RST First Edition
- Occupation
- Real Estate
The odor will return. This is not a Rivian specific problem though some makes and models do have more of a problem than others. The best long-term solution to keep it from returning is to turn off the AC and recirculate for at least five minutes before reaching your destination, but leaving the fan on to dry the evaporator.
Rivian should be able to do something software wise to prevent this for example by automatically running the HVAC fan for five minutes after the vehicle is turned off when the AC has been in use.
this issue is exacerbated if you park it in a non-climate controlled garage right after running the AC on hot days.
to put it, simply the goal needs to be to prevent the moisture from being able to sit there, and instead drying it out by using the fan to move air.
