Snow tire chain recommendations?
Forager
PNW
Structural Engineer
Looks like Rivian owner says not to use chains on the 20” AT or body damage is likely. Saw an excerpt in another thread. They recommend textiles (snow socks) on 20” and cable chains on 21” and 22” wheels.
Vegoelectric
Rivian R1T, Volkswagen ID4
As for that manual page... It's not the 20s that are the problem, it's that the tires on the 20s are 34" vs the 33" that come stock on the 21s and 22s. I'm kinda shocked that Rivian is claiming insufficient clearance even for cables. As I said in the other thread, I guess that also means there's zero hope of running 35s. I do wonder where the clearance issues are and whether as someone else suggested you could run cables if you were in Off Road / High mode vs Standard.
I think the tire clearance is only an issue in the front while turning. Nothing else makes sense. I have a set of AutoSocks, AL69 is for the 20's. Not as durable as chains, but I shouldn't really need to install them with the 20's. They are much lighter and easier to store/use. In CA it's a legal requirement to possess traction devices in addition to triple peak and 4WD. CHP told me that I won't need to install them likely as they shut the roads before requiring the use on our vehicles. They likely would come into play as a choice on a pass they are about to close that you are already traveling on, to improve your situation to clear the pass. Triple peak snow tires and winter driving experience will take you where you need to go. That said after watching videos on the Auto socks, they can really perform. I would like to see videos made by people who know how to winter drive instead of over accelerate then complain about wear/tear...
Taking a 5k mile road trip from CA over the Sierras and Rockies to Northern Wisconsin and back over the holidays. If I use the Auto Socks I will report back.
EricSD858
San Diego
2022 Rivian R1T
Anyone have a recommendation for good tire chains that fit the 20” ATs? I’m in the queue for delivery soon and will need them to access one of my favorite winter destinations. The Owner’s Manual seems to come up empty for this, which is unusual.
The service center told me there is a type of plastic beaded snow traction device you can use. I am going back there in two days and will post the ones from Amazon they said to purchase. This is for the AT20.
Vegoelectric
I drove in crazy winter conditions in several states on that journey and never was required to put on traction devices. The triple peaks performance is great for someone with experience. None of the states that had chain rules in effect required me to install, I was waved by when they saw the tires. The autosocks took up little space and are extremely lightweight. They will do great in my book.
ActionableDave
Temecula, CA
R1S Launch Edition, LA Silver 22 Sport Bright
Market Research Executive
In case anyone is interested, CA refs on chains:
CHAIN REQUIREMENT LEVELS
When chain controls are established, signs will be posted along the road indicating the type of requirement. There are Three Levels of Chain Requirements in California:
  • Requirement 1 (R1): Chains are required on all vehicles except passenger vehicles and light-duty trucks under 6,000 pounds gross weight and equipped with snow tires on at least two drive wheels. Chains must be carried by vehicles using snow tires. All vehicles towing trailers must have chains on one drive axle. Trailers with brakes must have chains on at least one axle.
  • Requirement 2 (R2): Chains or traction devices are required on all vehicles except four wheel/all wheel drive vehicles with snow-tread tires on all four wheels. NOTE: (Four wheel/all wheel drive vehicles must carry traction devices in chain control areas.)
  • Requirement 3 (R3): Chains or traction devices are required on all vehicles, no exceptions.
usulio
That's odd, a heavy truck like the Rivian needs to chain up for R1 but not R2?
Would be interesting to hear if anything ever came of this...
Ceejay
Canada
R1T 2024 Dual Large
I've got Blizzaks LT275/65R20 and need to have chains for a local destination. The local store has chains that say they fit this dimension of tire, but vehicle clearance during turns etc. is a separate matter. Anyone have any updates on whether chains can work?
Rivian specifically says not to use chains. Use snow socks.
Ceejay
Canada
R1T 2024 Dual Large
yes I've read that, yet socks are not an option.
The application will be short distance, slow moving. Can put in high suspension.
Not really any other options other than dedicated snow tires then.
Ceejay
Canada
R1T 2024 Dual Large
Oh I see you didn't realize: I am running dedicated winter tires: Blizzaks.
The chains are for serious conditions getting to and from my house that occasionally appear each winter, and a local recreation area which requires chains. Both short distances and going slow to prevent catastrophic consequences.
Cycliste
Solano County, California
Amateur aero weenie
Does the regulation specify ‘chains only’ or ‘traction device?’ Does a Sno-Cat require chains instead of its traction device? I would guess signs might say chains, but in the details, traction device is allowed. It’s just easier to say 'chains' instead of 'chains or a traction device.'
Whale Blubber
Austin
2019 BMW X3 3.0si, 2021 Toyota RAV4 XLE
I haven’t used these so I’m not endorsing them in any way but I think these might work with the R1 vehicles and supposedly meet state requirements: https://autosock.us/
I have used them (on 22" R1S Quad) and they do definitely help in snow; less grippy on ice than chains, but still better on ice than bare treads (but snow tires are better still).
Ceejay
Canada
R1T 2024 Dual Large
thanks for people weighing in. No regulation to get up and down from my house, just a nasty hill. The local rec area blocks vehicles without chains; not sure if socks would pass muster.
Again to be clear, I've already got winter tires on (Blizzaks), but these aren't good enough in certain conditions... if I get around to it I'll make a video of the situation and chains (If I proceed to try out), alongside the other videos I'm intending to finish making for my new channel
cheers
Cycliste
Amateur aero weenie
