RealWheels' new method of adding the power lead should solve this problem. Or, you can just keep it simple and add a single 500 Hz Hella horn (or similar type) to your existing single Hella-sourced factory horn (which is probably a 300 Hz), using a plug and play Y-splitter that you can order from Amazon. Hellas come packaged with a small bracket, most horns of this type do. Even the generic copies from China that you see all over eBay and Amazon. There are past posts with links on which particular harnesses to get (I have spare ones I can send you). I'd say removing the various frunk trims (if your factory horn is on the driver side) is probably the most and only difficult part. And those xmas tree plastic clips/fasteners will break on you. Best of have an assortment of replacements handy.I am rooting for you OP. I am really curious what the problem was. I always think of doing something like this; but my lazy bones keeps me out of trouble.
