Supercharging limitation - is this new?
CharonPDX
Charon
Cascadia
InfoSec Geek
Even if it applies to five individual SC sessions, that would be 1000 mile days so not much of a limitation unless you are doing a Cannonball Run Challenge.
An original BMW i3, VW Golf EV, or similar low-range EV being used as ride share in an area with long high speed drives common (taking people to/from airport that is 20 miles out of the city center) could easily have a need for 5 recharges in a day.
But I would assume that would be a rare use case. I would imagine someone doing that would want a longer-range + faster-charging vehicle.
SSteveEV
Spencer
R1T, etc
I'd think it makes more sense to limit this by kWh not by number of plug ins. But I have a big battery so probably better to not make that change.
RivianRunner
Marcus
Bellingham, WA
Cybertruck DM, F-150, Suzuki DR650
Tester
If you do the micro charging method adding more stops but staying at lower SoC to keep your charging times to a minimum, it would be very easy to hit 5 - but then, with the TSC you only get max kw's for 7-8 minutes as opposed to getting it up to 47-50% at other stations.
7-8 minutes of Supercharging in my Model 3 usually gets me up to around 47%-50%. It happens so fast I generally am not ready to leave yet.
LivingInKaos
R1T Launch Green Forest Edge
The battery in the Model 3 is much smaller than the R1T or R1S, so it should get you more SoC faster.
Jiji
Rick
Finger Lakes, NY
github.com
Rivian Blue R1S
I was referring to personal use, without multiple charging failures which is my usual experience when on the road using DCFC charging.
Commercial use, towing, a string of bad luck with SC connections and other situations that I can’t even imagine are likely to run into the Tesla discount limit.
