Where is the 12 volts?
skookumracing
Skooks
Enumclaw WA
R1T, BMW i3, Volvo V90 CC
pc500
dodge ram
The power port I gave you is the same spot as the factory 12v.cig plug. It'll go on off with the normal interior accessory power.
Joules Burn
Joules Burn
Morris
2026 R1S, 2022 Kia EV6 GT-L FE
Retired Electronics
Don't use obdii for a ham radio.
Fuse 28 I think... Left kick panel under driver. You'll have to make a fuse tap as the type rivian uses is exotic, but some trimming with pliers is all that's needed.
I used 15 amps because it's what's I had, but I think you could do 20.
Thanks. Agree. The transmitter wants 15 amps for full power. I've been "not letting well enough alone" for five decades so I have an ample junk box with various fuses and connectors. 20 amp fuses are installed in F46, F51, and F54 seem to be dedicated to a "12 volt port". I think two of those go to the "missing" dash and frunk ports.
Damn fine adventure vehicle but not designed for efficient field repairs. ?
Joules Burn
Joules Burn
Morris
Retired Electronics
Oh this is cool! These are new to me, but I think the concept.
I am one of the lucky few that has 12V sockets so I haven't been as compelled to get as creative as others here.
Good luck with your project. Interested to hear about what radio you install.
If all goes well, a Yaesu FT-2980 with a Larsen glass mount antenna.
pc500
dodge ram
The one for my missing frunk port had a fuse. The one for missing dash did not. In any case, it's > 15 amp, and your duty cycle is low, so I think that radio will be fine.
WSea
Patrick
West seattle
R1T, Outback
Architect
120 receptacle under backseat screen
TexasCrane
Austin, TX
'26 Quad R1T, '24 Ineos Grenadier
I’m a ham - amateur extra. I’d be curious how much qrm the vehicle generates.
Honestly though, I haven’t bothered with installing a 2m/440 in my last few vehicles. My 2 cents is that if you’re actually trying to maintain comms in remote areas, an inreach or sat phone is a way better solution.
