While waiting for R2 and V2H
SHRED
Ted
Encinitas California
Honda CRV and Toyota Camry
I am very interested in vehicle to home considering I'm under the outrageous (investor owned) SDG&E rates from 4pm to 9pm at 80 cents per kwH plus I had an Enphase 5kw solar system installed in 2022.
I realize we're looking at next year potentially for V2H so I'm looking for a bridge until the V2H capable Enphase chargers hits the market and the R2 gets a firmware update to unlock it.
Could the portable charger be used with a 240V outlet in the meantime?
emroch
Austin, TX
r2-dashboard.pages.dev
2027 R2 Launch Edition, Chevy Equinox
HW Verification Engineer
Rivian doesn't currently support any form of V2H (though they claim the hardware is present in Gen2+). So even if the mobile connector could backfeed your home (which I'm not sure it would even support electrically), the car just wouldn't do it.
If you're looking to be self-sufficient in the meantime, you'll probably need to install home batteries. That's probably a reasonable project even with V2H as the car wont always be there and wont always be charged. You could down-size the battery system knowing that you'll eventually have another 80kWh of capacity eventually, but I would not bank on that happening within any certain timeframe. If Rivian ever publicly abandons the V2H initiative or takes too long for your needs, you should be able to expand the home batteries pretty easily down the road.
emroch
Austin, TX
I have a 10kWh Anker Solix X1 system installed and would love V2H as my batteries are usually depleted by bedtime if the AC is running (which in ATX it usually is). My old PV array wouldn't be able to fill too much more than 10-15kWh in a typical day anyway, which is why I didn't go bigger off the bat. But having an extra 80kWh for emergency backup would be amazing.
SHRED
Ted
I'm finally get difficult to plan for v2h not knowing the time frames.
Redmond Chad
Redmond, WA
R2 (Silver/Black, 21"), Tesla Model X, Brightdrop camper
I agree with emroch that, absent OEM-provided V2H, having home batteries could be a good intermediate step. Be careful though - a lot of home backup batteries will not take 120V input (from your car) and do 240V output (to power your home) at the same time. And they often don't list that "feature" on their web site (in fact their wording may make it sound like it will work), so you may not discover it until there is a power outage.
My older Ecoflow batteries are this way. I tested to make sure they could power the house, and I tested to make sure I could charge them from my R1S...but didn't discover that I couldn't do both at the same time until there was an outage. See HERE for more details.
There are systems that will work as expected.
KBabione
Kevin
Lititz, PA
2023 R1S Quad (8/23)
daeHelkcunK
Naples FL
1965 Suburban, 1968 Chevelle, Cayenne S, R1T, R1S
Physician
Next EV that I buy must have V2H capability or it's a hard no. Rivian has the might to bring this to fruition, maybe spend less engineering time on electric bikes and more on what people really need. There are an ever increasing number of people facing power outages. Why don't they see this as the priority it is? This is really my only criticism of an unbelievable company
Jeremy3292
Jeremy
South Carolina
R2
Bc it’s really not a priority for a lot of people. That being said all the hardware for V2L and V2H is in R2.
a9967
R2, Hyundai Palisade
R2 has an 11kw dc->ac inverter onboard. You don't put serious hardware like that in there if you don't have plans.
morph860
NSB, FL
‘24 Wrangler 4xe, Rivian R2 reservation
I'm interested in seeing what they announce for V2H as well. I have a JuiceBox 40 J1772 charger right now. I was going to replace it with a Tesla NACS charger, but I think I'll hold off and use an adapter for now. And then maybe someday I can replace that with whatever their V2H solution is. I'm sure that will require a specific wall charger.
BigSkies
R1T, Model Y
For those waiting for V2H, I would suggest keeping expectations in check until more information is available.
It's not an accident that the Ford/GM options that exist can involve $10k+ of electrical work to a house.
These systems involve a lot of big wires, main panel work, and safety considerations. Expect improvements to come at the pace of the electrical code, not at the pace of AI companies.
MrBritton
Land Rover LR4
Does it? When I tried to confirm that a while back, I couldn’t find any official evidence, so I concluded that people might be mistaking an unclear statement about the level 2 ac->dc charging inverter (which, of course, all EVs have). That said, it might be that the charging inverter was designed to also operate in reverse.
gene1138
NJ
tesla model 3
There doesn't seem to be a lot of printed information about V2H but Vidya Rajagopalan from Rivian mentioned it in this interview with Tom Moloughney from State of Charge. Video linked to relevant part of the interview.
The 11kW figure came directly from RJ.
MrBritton
Land Rover LR4
As you say, RJ certainly seems to indicate that ”10 or 11” kW AC can be provided by the R2. What mechanical/electrical form that will take remains to be seen. A new bidirectional Level 2 charger? A higher capacity Field Outlet? He also said they’re working on a DC bidirectional charger. I’m skeptical that they’ll get around to providing both in the near future, but I would sure like some high power solution, sooner rather than later. That said, I completely understand how developers like to hedge their bets with capabilities that might, or might not, come to fruition as a product, depending on market evolvement and resource allocation. Announcing those hedges too early or without a real plan to implement can frustrate customers, but calling them a scam, as someone did, is a bit immature.
