Wiper refills OEM
Voronbrg
Jay
Everything
Ok. I purchased the refills from my Mazda dealership. Now, can someone explain how to remove the original rubbers from the frame? I put the vehicle in wiper service, I remove the frame from the arm. I don't see how the rubber refill comes off the blade. Thank you in advance
slide the rubber out along the tracks , replace and slide back in.
Voronbrg
Jay
Everything
Can you clarify which part number is for driver, passenger? I have an R1T so I’m wondering if your providing part number for an R1S for the rear wiper too. I have no rear wiper so I don’t want to order a part unnecessarily. Thank you.
No, theyre only for the fronts. I have a r1t as well.
Voronbrg
Jay
Everything
The Mitsuba part numbers
Driver side 24”: MOB2-S2-105 600mm
Passenger side 18”: MOB2-S2-085 450mm
https://www.amazon.com/gp/product/B00BFDG118/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
here’s a thread with similar parts discussion for silicone refills https://www.myg37.com/forums/genera...ne-wiper-inserts-for-the-oem-wiper-blade.html
https://www.myg37.com/forums/general-tech-questions/281604-wiper-refills-important-fact.html
Personally I will be trying these PIAA SMR600 and SMR450 https://amzn.asia/d/8VMtJKc
silicones may last longer and have wider temperature range but they tend to squeal without special coatings applied to the windshield. It's added effort to maintain a coating than replacing refills. hence why they aren't factory wipers.
djsider2
E
Bay Area, CA
Did the rubber insert part numbers change to BDTS-67-333 & BDTT-67-333?
primedir
Sean
Bethesda, MD
R1T, Nissan Leaf
Thanks for posting this information. I picked up the blade inserts at my local Mazda dealer and swapped them into my R1T in about 10 minutes. Half the price of the Rivian replacements, much less material waste, and available the same day.
Mazda parts BBP2-67-333 and BHS3-67-333.
swflor
NC
Executive
You can also get the Michelin Blades (frame and rubber) from Costco for around 8.99. Fit perfect and have lasted. I usually do new blades once a year to keep them in prime condition.
dradam
Anyone found an insert replacement for the rear wiper on the S ?
Adding to thread... the OEM articulated frame can look dull from sun damage. Cerakote Trimcoat does a good job to restore and protect it. If you are replacing the rubber blades, it's a good time to clean and treat the frames.
I could be wrong, but I think width of blade refills are pretty much universal? It's the length that's important. If you know length of OEM blade, buy a couple refills in that length to try. Wouldn't hurt to measure width of original.
TRap015
I have been waiting for 2 years to see if anyone have done any refill for rear wiper. All I know it’s 10” for the rear
FooF
FooF
Mountain View CA
foof.me
2022 R1S Launch Green
DJ
Any suggestions for silicone blades?
I have been using these for a couple of years and they are still working well.
Rivian R1T R1S Wiper refills OEM 51yTEv5GXML._SY115_SX115_
Piaa 97060 24-Inch (600mm) ...
Qty : 1
Piaa 97045 18-Inch (450mm) ...
Qty : 1
mudito
Aldo
Don't have an R1S myself, but this one is the one I used in several vehicles https://amzn.to/4az2Syk
You can cut to whatever length you need it :)
Yossarian
SE Pennsylvania
Anyone have experience with the Aero Voyage blades? They were one of the brands recommended in a C&D review of wiper blades and come with a set of replacement blades, making their already modest $25 per pair price effectively half as much.
The Amazon website says that they don't fit Rivian, but it's hard to how that's possible. They are available as a standard J-hook attachment and in 24" and 18" lengths. Why wouldn't they fit? For the price, it seems like they'd be worth trying.
Dave Cundiff
Dave
Pacific County, Washington
I had an R1S rear wiper replaced at our Rivian Service Center. Reasonable price, no drama.
Best wishes!
Dave Cundiff
Dave
