Wish the speed limiter could be increased
JamboF4
Jim
Ponte Vedra Beach, FL
R1T, C8 ZO6, Tacoma, Arcimoto
Retired airline Captain
IMHO you don’t need that kind of speed in a truck or suv. I’ll take the corvette when I want to go fast, that’s what it’s made for. My wife and I always get a big chuckle when we see an suv or mini van that says sport.
Speaking of which, the ‘25 QuadMax will lay down the same straight-line numbers as a ‘24 C8 ZO6! Freakin’ amazing
R1Thor
Joe
Lancaster, PA
Mechanical Engineering Lead
There is no autoX on earth where you need a raised top speed and for that matter, literally no one will be autocrossing a Rivian...at least until the R3 comes out. Now road course and drag strip would be nice, but you're never going to get this except in some geofenced mode. G2 tri/quad get a launch mode that allows up to about 130 mph at the drag strip and the quad was shown to do 10.5s. The other limitation is tires...most of the available aftermarket replacements top out at a T rating with 118 mph.
I thought about AutoX.
I've done it in the past with a hilariously underpowered Neon, and then later with my Subaru STi (that was FUN).
However, my concern is honestly the tie rods. That kind of weight thrown into corners repeatedly, the problem isn't losing traction, it's accidentally getting more traction than you bargained for (SNAP city). That's the purpose of the tie rods, however...
I have seen people run TrackHawks and similar larger vehicles (there was even a convertible PT cruiser at one of the AutoX meets I was at). IT's all in good fun, but I personally wouldn't risk it with my R1T...
But anyway we digress, other than I agree with you 100%. NO one is getting above ~50mph in an actual AutoX. Maybe a RallyCross, but that's another set of worms you're also NOT taking an R1 platform out on.
DayTripping
Timothy
DFW
I wish the speed limiter could be increased to 135 with some track tires would be nice. It sucks that the truck can do 11.6 quarter mile @110mph at best. I would guess it could do 10s if the cap could be raised. Gen 1 R1T Quad.
Add me to this group, at least for track use. I'm not sure my quad will get in the 10's, but it could be low 11's.
A: Not useful. For most drivers, there aren’t that many opportunities to go that fast. B: While you might be competent in car control, 7k+ lbs times >110 mph… what could go wrong? /s. C: Look at all of the tire threads and see what non-stock tires people are choosing. Again, what could go wrong? /s. D: Top speed is not where BEVs shine. It’s acceleration.
Some valid points, but why did Rivian raise the limiter on the G2s? As for point "D", I think that is done mostly because at top speed, your range would be pretty atrocious. To put this in context, at the dragstrip with my Model S plaid, I'd use 2% of my battery for each pass. I'd usually trap in the 150's. If I made one wide open pass until I hit top speed limiter of 203-204, I'll use about 5%.
You have to run the optional carbon ceramic track pack brakes for Tesla to raise (not totally unlock) the top speed limiter. I basically hit 200 mph between 3/4 to a mile after launch and at the half mile point, I am usually in the mid 180's. If Rivian wanted to add a brake upgrade/tire package option and raise the top speed of my quad, I'd be interested.
I posted a detailed analysis/opinion regarding the speed limitation a year or so ago. To summarize, I looked at documented specs for Bosch EV motors, Rivian's gear ratio, tire diameter, etc. and the math worked out almost perfectly to 112 mph top speed without exceeding the Bosch motor max RPM specs. I think it is a motor safety/warranty decision by Rivian and/or Bosch to limit the speed in Gen 1, not a "You don't need to go that fast" nanny thing.
Gen 2 uses the Rivian designed and built motors, likely providing a higher max RPM and/or using a different gear ratio.
zefram47
Rivian R1T, Alfa Romeo 4C
I've certainly hit 80 or so in my former Corvette, but that was very rare where topping out at 70 was more common. Powerful cars are fun for autoX, but still more fun if you can actually pull greater than 1G, which big/heavy vehicles won't, though tires are certainly a limiting factor for Rivians right now. I hit 1.4G in my Alfa. Concerns about other equipment breaking is legit. Most organizations also have limits on center-of-gravity and track width vs vehicle height.
Newtonrj
bloomington, il
Porsche Cayenne Plugin Hybrid, BMW 335i, M3, 325i, VW GTI
Goes both ways. Seen too many crazy attempts at street cars trying to be off-road or dune trucks.
Rivian R1T R1S Wish the speed limiter could be increased xggg9ho5gsruxzlupapa1
ElGuano
Cali
Wow. Surprised the floorpan is rigid enough to prevent the vette from taco'ing.
Newtonrj
bloomington, il
Just in case folks wonder about tire capabilities on the G2 Quad/Max, Rivian is supposed to put these wheels on 22-inch Michelin Pilot Sport 5s, with a staggered position of 275mm width in the front and 305mm in the rear. These will carry speed rating in the W and Y class above the 130mph top ceiling Rivian is planning for the speed cap.
Rivian R1T R1S Wish the speed limiter could be increased Pasted Graphic
DayTripping
Timothy
DFW
I don't understand the desire to go with a staggered setup especially on an AWD vehicle. You can't rotate the tires and any treadwear warranty is cut in half.
If they had something like track mode that Tesla has, my old Tesla had a top speed of 135mph. This isn't for public roads but the weekend doing auto-x and quarter mile track. On the highway I'm lucky if I do 75mph.
Are you forgetting, still, that the R1s are not small passenger cars, weigh 7k+ lbs and have much higher center if mass? How much did your Tesla weigh? There is also the issue of the tires’ ability to stay seated on the wheels—under dynamic load/stress of 7k+ lbs at speeds greater than 110 mph. Why are these two figures significant? See Newton’s second law of physics. And none of the popular non-factory tires are rated higher than 115-120 mph.
Raising limit is a solution looking to create problems. Want to go faster? Upgrade to Gen2 Tri or Quad Acsent with the Michelin Pilot Sport S5.
You answered your own question. Those wanting ultimate on-pavement performance don’t care about tire longevity or efficiency. Engineering is a game of compromise. If you want more of something, out of same machine, you have to give up something else to achieve it. It’s the same with high performance sports cars.
It's just like putting a wing or open exhaust on a street car - the owner thinks it looks/goes/handles better based on the mod and their "seat dyno", but it really is essentially all show, no go.
Stagger is really only beneficial for rear acceleration traction, unless the car's suspension & balance has been designed/tuned to compensate for the stagger, i.e. Porsche 911, Corvette, BMW "true M" series, (not M Sport), etc.
mkg3
R1S, Model 3, Outback, Artura
Actually, it has either H or V rating. I cannot recall which but it's been discussed and I thought it would be higher rating but someone on this forum provided a clear image of the tire with the speed rating on it. It's a special tire made for Rivian. Also Michelin changed the naming convention to Pilot Sport Super 5 (PS S5).
So no, Rivian will not be 3 ton+ block of metal flying down the road at 150mph...
R1Thor
Joe
Lancaster, PA
Impressive!
I guess I can only speak to my experience. NEPA SCCA and Central Pennsylvania SCCA both do AutoX generally in mall parking lots or similar. There is 0 chance you're getting any kind of speed. Your longest straightaway is probably 1000' at the *most.* Quick math suggests to get even 0-60 in 1000 feet, you need a 2.5 second 0-60 car, so definitely not hitting 80, and in reality, you'll be braking well before that 1000 in order to get prepared to turn (typically 90 degree, into a chicane or similar).
Good times all around, though!
