Luckycharms783
See I knew someone smarter than me could explain why there hasn't been a lot of DCFC installed in needed, but underutilized, locations!It depends on usage. Taken to the extreme, let's say there is only a single charge in a month, peaking at ~220kW for a total of 80kWh. That could cost them ~$6,600 for the demand charges and ~$4 for the energy charges. Obviously, they can't charge a single person $6,604 for a charge. (Demand charges vary by region/utility but are often between $20 and $50 per kW, I figured at $30/kW.)
Say you wanted to get it down to $1/kWh you would need to get ~85 charges per month, or three per day. But if you have two of those charges overlap, your demand charges double to $13,200, so then you need ~6 sessions per day to keep it at $1/kWh. But that increases the chances of having three simultaneous charging sessions, increasing demand charges to $18,000. (Assuming a maximum station capacity of 600kW.) So, you would need ~8 charging sessions per day.
Do you think there is enough demand for at those sites to get ~250 charging sessions per month? Even when charging $1/kWh?
Edit: I found one rate structure for a random place in Utah:
So, demand charges are only about $20/kW. (Facility + Power). So maybe it would work at ~175 charging session per month.
Tesla does vary their rates per station, and even time of use. (Electrify America on the other hand charges a single rate country wide.)
