CDC_73
Chad
Vista, CA
2023 R1T Quad
Sales Engineer
Quick review on the tonneau cover from Tail Lidz.
Packaged nicely. 3 panels with a weather seal strip on one side. Definitely hand made and assembled, the corners are a little rough.
The sides and the corners do recess into the track, so you can't see the gaps / finish. The panels are light, but sturdy and are very snug in the rails. You have to really push them in to make sure the truck registers the tailgate is closed.
They will do a decent job of sealing just due to the pressure from the tailgate, but definitely not water proof.
Panels do fit in in the gear tunnel. They do look very good installed.
I would consider them over priced, but give the lack of options for us without the motorized (maybe broken) cover, they will do the job well and are solid.
Rivian R1T R1S Tail Lidz Manual Tonneau Cover installed photos & review IMG_0985
Rivian R1T R1S Tail Lidz Manual Tonneau Cover installed photos & review IMG_0987
Rivian R1T R1S Tail Lidz Manual Tonneau Cover installed photos & review IMG_0988
Rivian R1T R1S Tail Lidz Manual Tonneau Cover installed photos & review IMG_0989
seanocono
Sean
LA
Tesla Model X Plaid, GMC Sierra Denali EV
Thanks for sharing your review. It's a bummer about the rough corners, but it does look really nice installed. What's your impression of the durability of the carbon fiber wrap?
CDC_73
CDC_73
Chad
Vista, CA
2023 R1T Quad
Sales Engineer
The wrap seems pretty thick and should hold up to normal wear, I would not want to drag anything heavy and / or sharp across it.
seanocono
Sean
LA
Great! Thanks for the insight. I think that would apply to any tonneau cover material, including the original, powered tonneau cover.
RivAW
Alex
MA
This is great but def overpriced by at least 25%, maybe more…but I suppose it is the only option reasonably similar to the promised OEM manual cover panels. By the way, “early 2023” is almost over so an update communication from Rivian would be nice.
CDC_73
CDC_73
Chad
Vista, CA
2023 R1T Quad
Sales Engineer
It would be interesting to see these aluminum panels sprayed with Rhino liner or some other rugged material.
Thanks for the review. For that price I would expect better finished corners?
Christopher
Christopher
South Florida
Tech
I would love to see ones made out of a starboard type of material that could take a beating and you wouldn't have to worry about paint, powder coating, etc.
Riv_Ian
Ian
Rivian R1T, Audi TTS, Triumph TR6, Tiger Explorer
CEO
A 10mm thick 5’x10’ panel of alumalite is $365, which should be enough for 2 vehicles. 5’x5’ of carbon fiber vinyl wrap from first place I found is $225 (enough for just the top; double for both sides). Guestimate of $100 for edging (not sure if plastic or aluminum, lip seals?) puts it at $500-725 for materials. $1000 sell price doesn’t seem way out of line.
I would think using the tough painted coating approach, it would be possible to make your own for well under $500.
DTown3011
My thoughts exactly. Thats a hard return in my opinion, no way I accept delivery like that for $1,000.
Millertimr
Jake
Hyundai Tucson Hybrid
CDC_73
CDC_73
Chad
Vista, CA
2023 R1T Quad
Sales Engineer
Christopher
Christopher
South Florida
Tech
Based on your back of the napkin math on material costs, the sale price of $1000 is aligned with typical profit margin of manufactured goods.
Rivianation
Florida
Manager
The rough corners seem on purpose, where they grinded down the edges to make it fit better.
I'm more worried about how that material will look under direct sun, after a couple of years.
