Installed yesterday but haven't went anywhere yet to test anything out.
Ajax
Ajax
Mid-atlantic
2025 R1S dual motor, Mustang Mach-E Infinite Blue 4x ER
I was having the proximity sensor issues so I started installing this around 8:30 this AM. It's 9:35 and the update is stuck at 7%. My wife needs the car in 20 mins and I might be in the doghouse if she can't use it. I'm guessing it's really bad to try to abort an update?
mclark2112
Matthew
NJ
Finance
Mine just finished, it took maybe 45 min. I won't be out driving for bit, but the reverse throttle mapping should be interesting. I'd love a coast mode so I can hover over over the brake like a normal car, seems like it would be safer.
Golfer04
Illinois
Finance
Your update isn't going to install. 7 percent is where it fails. Mine did that last month and ended up having to go to SC to have installed. Do BOTH resets before you call service and they will push it a second time. They will not push it a third time. Will send you to the SC. Mine failed yesterday too. Did the resets and am trying again now.
iforbes
Ian
Connecticut
APRN
Seems as though the charging mismatch is fixed.
after initial load, safari,er infotainment feels snappier.
no need to sort reset for audio. Sounds good in all channels, not sure about volume improvement between songs
hvac colors much bolder
Golfer04
Illinois
Finance
And, btw, I am having sensor issues too. Supposedly this update will fix them.
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
Took about 30-40 minutes on the gen 1 R1T. I noticed reverse is much smoother but allows more of a coast without hold engaging. Too early to tell but I think I’ll probably prefer this if it’s consistent. I was in snow mode so I wonder if that changes anything in the reverse behavior…
otherwise infotainment subjectively seems more responsive…
Seano
Sean
Nor Cal
I got my update mid day yesterday. The reverse throttle behavior is way smoother. Now I just need to install the rear camera washer line I’ve been meaning to get around to all winter so I can see where I’m going… that and/or some reverse lights that are actually sufficiently bright to see anything over the blindingly bright smudge on my screen all winter.
I’m a little annoyed about two things, however:
  • They didn’t add the ability to change lock behavior on other locations than home. They should have “trusted locations” (work, second homes, wherever) where you can tell the truck not to proximity lock. I’m particularly bummed that they didn’t at least add Work as an option, given that they just added the ability to have driver profile-specific locations.
  • They eliminated the seatbelt as an option to “keep” climate running without going three taps in for dog mode. I can’t believe they don’t have an option to keep the climate running when you’re getting in and out of the truck to run errands/etc. I wish I could just set a default “run for 5 min after exiting vehicle.” Or have one icon right on the top of a fan that you can press that leaves it on indefinitely (maybe it could notify you when exiting the truck that you have it left on, and/or give an app notification after 15 min that you could say continue or end with).
I would love both of those features, too. Not sure if you've tried it (and yes its a few taps), but now when I'm in our other garage I just set location as home. May be irritating to do everyday at work, but works well.
PeterSK
Peter
Cambridge, MA
2023 FG/FE R1S, 2021 Model Y
Retired / board director
You do know you can wash the rear camera, right? Put the car in reverse, long push the rear wiper button on the end of the turn indicator stalk to wash the rear window. It will also spray a jet on the camera - but only when you're in reverse.
And only in an R1S... He's got an R1T.
blcklab666
San Diego
R1S, Sprinter 144 4x4
Alexa voice commands still don't work with Spotify.
Had a frustrating conversation with Rivian yesterday about Alexa/Spotify, if you're having this issue please open a ticket so they can see the depth of the problem.
what did they say? This is so frustrating. Started for me July or August of last year but at least media reset temporarily fixed it then. Doesn’t now.
they have me bringing it in to SC, again, and I have zero confidence they’ll fix it. Meanwhile wassym acknowledged on Reddit the issue existed 2 years ago.
