ACDC
Michael
Portland OR
2013 Outback, 2012 Tacoma
Thought this was an informative video... bonus points given for Rivian on cover image :like:
"There’s a lot of talk and information about EV tires. Some of it’s good. Some of it’s wrong. Most of it is somewhere in between. In this video we try to cut through the opinions, hype, and propaganda to provide real, testing-based answers to some of the tough questions surrounding EVs and the tires they use."
R1 EVY
Darren
Milwaukee
2023 R1S
Entrepreneur
This is so good. I learned a lot. Now I can choose a tire with a little knowledge aka way more dangerous!
VSG
R1T LE/RB/OC/20
Of course you need EV specific tires!
For the low price of $550 each...don't buy those $200 tires, please!
Is that supposed to be sarcastic?
That's not what the video says ...
VSG
R1T LE/RB/OC/20
I was honestly pleasantly surprised by the quality of the information in this video.
Some may see it as "wishy-washy" because it gives a nuanced evaluation of tires.
And some may not like it because it doesn't give you a direct solution to their question of which tires should they buy.
But to me, it covers all the factors that influence tire choice: Wear, Price, Performance in different conditions; and Efficiency.
For everyone who thinks there should be a black-and-white tire choice, this video will disappoint you.
For those of you who approach the subject as a typical consumer who is willing and able to make tradeoffs to get what you want - this video will lay out all the important points to let you decide for yourself.
The only other comment I would make is that OEM tires are chosen for a specific purpose. In the case of EVs, one of the main reasons for the OEM choice is to maximize the range. Consumers (and EV consumers in particular) buy a vehicle based (in part) on EPA ranges, so a tire that maximizes the EPA range (necessarily at the expense of other variables) is the preferential default tire for the manufacturer. YOUR NEEDS MAY BE DIFFERENT. But if you are focused on efficiency at all costs, then the OEM tire is probably the best choice - that's why it was picked in the first place.
JamuJoe
Joseph
Hesperus, CO
RAM 2500, Polestar 2, R1T Max Pack Performance
Retired Petroleum Engineer
Thanks for posting. Very informative and balanced. IMHO, Rivian and Pirelli got it right with the 21” Scorpions. As a long time Michelin driver, I was skeptical, but 7300 miles later, through a CO winter and a 3800 mile tow with our 8000 lb travel trailer, I am very satisfied with the Scorpions. Just had them rotated and balanced at Discount Tire (free) and they show minimal wear.
mikehmb
SF Bay Area
What we need is a standardized rolling resistance measurement for tires. Ideally, standardized measurements for every other metric as well, but I’ll be happy with just the first for now.
djsider2
E
Bay Area, CA
Is it required from a LEGAL point of view? Will my insurance NOT cover any issues I cause if I don't go with "EV" tires?
Gen(R3)Xer
Ohio
Honda Fit
This was a great video. I love Tire Rack. I’ve used them for years.
VSG
R1T LE/RB/OC/20
No not at all.
If anything, I would say that "EV Tires" is a marketing phrase aimed at people who consider efficiency the most important factor in tire selection.
Not that efficiency is bad, but some people have different priorities other than efficiency. If you live in the snowy mountains, and have to drive in those conditions > 6 month of the year, then efficiency might not be the most important factor in your tire choice.
Regardless, watch the video; it's worth your time because it covers all these things.
ndmiller
Noah
Atlanta
R1T Incoming
Retailler
There is no such thing as EV tires, it's a marketing term used for low rolling resistance without any proof or data to support the claim.
Get tires in an appropriate Speed and Load rating, maintain air pressure and rotate on some schedule, same as any other vehicle. EV's are just heavy vehicles for their size.
iansriv
Ian
That sounds premeditated (j/k). I'm on ATs so efficiency is not my priority. When it comes time to change, I'll only be looking for the base speed/load rating.
brancky3
Brandon
Greenville, SC
22 CY R1T, 21 MachE GT
EV tires are a real thing, it’s not just marketing. Whether or not those real things are important to you are another story (sound insulation, lower rolling resistance, etc).
