39.1 OTA bugs (compressor, audio controls, etc.)
_evtrk
Miami, FL
'89 Trans Am GTA, '22 Rivian R1T, Pre-order '26 R2
General Manager - Retail & Service
my compressor is also dead after update, can confirm as i was using right before i started the update and hasnt worked since the update finished, vehicle air suspension still working perfectly fine
MikeySea
R1T, Model X
Gainfully unemployed
Good news! The update can go well. Used the compresser before and after and it works fine. Install took about 55 minutes. Haven't tested Driver+ yet but assume it still doesn't work due to. wheel alignment issue. Had this issue since day 2 and service isn't until January 16th...the s00nest available
Curious about your wheel alignment issue. Are you having the issue where Driver+ sporadically won't engage and the driver display shows "wheel alignment needed, please service vehicle" msg? I noticed this problem surfaced coinciding with an OTA a couple of revs back. I spoke with Service who said they aren't aware of an issue. But since my truck doesn't pull to either side, tracks straight if you let go of the wheel, and the fact that 50% of the time Driver+ works -- I am suspicious this is a bug vs. sensor failure. Were you able to get any specifics from Rivian about the problem? I was going to make a service appointment, but Bellevue is already scheduling well into Jan of next year.
WSea
Patrick
West seattle
R1T, Outback
Architect
Nothing from rivian besides confirming it’s on my service request. Initially I had no alignment issue while getting the wheel alignment needed error. Now it goes pull right. my hunch is a sensor or recalibration
WSea
Patrick
West seattle
R1T, Outback
Architect
Have you tried a hard reboot?
MikeySea
R1T, Model X
Yep, had to call service on unrelated issue (truck wouldn't release the charger). Service had me do a hard reboot but it didn't resolve either issue.
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
I couldn’t help myself and started the update. Luckily compressor display and audio select buttons are still working!
I did here some spooky sounds coming from the truck towards the end of the update.l, a descending series of tones but very soft.
Add me to the list of failed air compressors. Submitted a ticket and got a call back within an hour. They know this is an issue, but don't have a repair plan from engineering yet. But rest assured they are WELL aware of the problem thanks the community feedback! Great job y'all!
AllInev
Oakland, CA
Prius V, 2022 R1T
The descending series of tones is something I’ve heard before when near or under my R1T, so it’s probably unrelated.
AllInev
Oakland, CA
Prius V, 2022 R1T
Darn. I guess I’ll hold off on this update for a bit.
CharonPDX
Charon
Cascadia
InfoSec Geek
Compressor works fine after update for me.
Atlrivian
Atlanta
Grand Cherokee, XC90
My compressor also works fine.
On a side note, I had put in a ticket for a Gear Guard issue (which was fixed with this update somehow), and happened to get a call from CS this morning while the update was installing. While on the phone about the Gear Guard issue, the CS representative warned me the air compressor might be screwed up by the update, but that they supposedly already had a fix.
gombater
Rick
Apex, North Carolina
R1T FE/FG
Engineering Manager
Well if you have not initiated this update you may want to hold off - mine failed about 3/4 of the way through.... now all sensors are offline - no Driver+ features.... all of them are disabled in settings and cannot turn back on. Waiting for guidance on next step from service - sleep cycle did not help.
but hey - my compressor appears to have power and I have kneel mode now....
connoisseurr
Connor
Northern VA
22 R1T, 23 MYP
I encrypt PDFs for Boomers
I just got 39.3. Anyone else?
