4.01 kWh club
MountainBikeDude
Vancouver
Not the left hand screen, but overall got to 6.3 kWh on descent from 11.3k' Berthoud Pass, CO to Denver circa 5680k'.
Ah the good old days, when the trip computer wasn't buried in layers of menus.
DTown3011
Joined this weekend coming down Monarch Pass headed back to Denver from Salida, CO
Rivian R1T R1S 4.01 kWh club IMG_3444
swhme
Sam
Santa Fe, NM
R1S, Land Cruisers, BMW 535&335, MB 300TD, Cayenne
Nerd
Rivian R1T R1S 4.01 kWh club 1694312749500
Cheers! Headed down from Los Alamos to Pojoaque
W1SE
W1SE
Jake
Vancouver, WA
2022 R1T Quad, 2024 R1S Max
Branch manager
Since I started this thread I had the opportunity to come west on I-84 out of the blue mountains into Pendleton, OR. That is quite a down hill. Descending about 3000 ft in 6 minutes. I was able to add 4 more miles in instead of using the 6 miles that I drove.
Then After traveling 15 miles from the start of the down hill I finally hit 0 kWh used. It’s was interesting because there is no negative on kWh used. so the kWh used was positive even though I gained energy (which should be negative) and kept decreasing until I hit zero even though I was flat and many miles past the hill. Fun experiment none-the-less
Rivian R1T R1S 4.01 kWh club IMG_1769
Rivian R1T R1S 4.01 kWh club IMG_1761
DMDK82
Dmitri
Vancouver, BC CANADA
2023 R1S, 23' BMW iX M60, 22' Tesla Model X Plaid
Construction Consultant
Turn off the Climate Control and you'll hit maximum efficiency faster with less of the prolonged grade ✌
W1SE
W1SE
Jake
Vancouver, WA
Branch manager
My rule is that unless I absolutely need those miles to get to the next charge I will not sacrifice climate.
But I guess I would also do it for an experiment or to have fun to see how high a number could go. But generally I think it funny how people will sacrifice something that takes such a little amount of juice (climate control) compared to what’s needed in moving a 7k lb vehicle. Through air friction at 70 mph.
DMDK82
Dmitri
I live in a very cool region and my wife has a phobia of AC lol
Climate Control will have same considerable difference that I observed just as of interest, it was slightly greater difference then conserve mode. I for one wont sacrifice anything for range, I use the vehicle how I like it, AC freezing and music blasting otherwise whats the point.
The difference on my iX M60 is quite significant, Ill post a video below
DMDK82
Dmitri
elektrode
Bran
NC
Honda Ridgeline to R1T
Bunch of show offs. :)
FooF
FooF
Mountain View CA
foof.me
2022 R1S Launch Green
DJ
Would be nice if the graph would show elevation as well. Many times mi/kw is low and not sure it it is wind or elevation change causing it. If mi/kw is high I just assume it is from decent from elevation.
W1SE
W1SE
Jake
Vancouver, WA
Branch manager
agreed elevation is a thing but luckily it will always end or reverse.
The big killer for me is wind. We drove east through southern Idaho at 85 mph and got 2.3 m/kWh. But 3 days later coming through that same stretch going west it was 1.7 m/kWh at 80 mph.
the constant wind in that area was probably 25 mph. Many signs have springs on them and they were all bend over just from the force of the wind
FooF
FooF
Mountain View CA
foof.me
DJ
High wind is pretty easy to hear but elevation change is sometimes hard to tell.
IPTV65
Mount Pleasant SC
Jeep JLU Sahara,Jeep JKU, Infiniti G37X, R1S
Engineering Exec
I don’t even try! :)
