mpshizzle
Utah
2025 R1S Dual Max (Baymax)
There’s been a lot of chatter (and conflicting information) about the Rivian–Volkswagen joint venture. What exactly is VW buying, and what aren’t they getting? Let’s break it down.
I go into more detail on the video - so if you'd like to watch that instead:
First - A Bit of Background
The TL;DR is that VW is buying Rivian's Zonal Architecture. But before we dig into WHAT exactly that entails, what is included (and what is not) we need to look at how most auto makers do electronics. Modern vehicles are essentially rolling networks of tiny computers (ECUs). It started with simple ECUs to handle simple functions. One to manage fuel injection, one to handle power locks, etc. Over time, automakers kept bolting on more and more ECUs for every new feature — power seats, ABS, airbags, lighting, you name it. Each ECU was often built by a different supplier, operating a little differently. Somehow, it all works, but it’s a mess when you want multiple systems to coordinate (like mirrors + lights + seat recall when you walk up to your Rivian).
If you were designing a car today, you probably wouldn’t build this Frankenstein system. Instead, you’d probably design a simpler, more robust system with fewer points of failure. Perhaps a... zonal architecture. (See what I did there? I'm rather proud of that one 😂)
Why Does VW Want This?
Today - VW's vehicles are very much stuck in the world of tons of tiny ECUs made by tons of suppliers. So there are a few key benefits they're after:
  • Consolidation: Instead of dozens of ECUs scattered around, Rivian divides the vehicle into a few zones (west, east, south in Gen 2 R1) controlled by powerful zonal controllers. These handle everything in their area — lights, locks, seats, etc.
  • Simplicity: In R1 Gen 2, Rivian cut down to ~7 ECUs and eliminated 1.6 miles of wiring. That’s huge for reliability and cost.
  • Scalability: The joint venture takes this Rivian design and makes it universal for VW’s fleet — from the tiny “ID Every 1” city EV in Europe to the upcoming Scout.
What VW DOES Get
  • Designs for Physical Components: ECUs, motherboards, connectors, and wiring layouts.
  • Software: The operating system that runs these controllers (Rivian’s current system is called Safe ARTUS. The one running on the JV's system will probably be a close relative).
  • Protocols: The communication systems that let ECUs talk to sensors and each other across the network.
Put simply: VW is buying Rivian’s vehicle nervous system.
What VW DOESN'T Get
This is where a lot of confusion online comes in. The deal does not include:
  • Powertrain & Battery: Rivian’s motors, inverters, suspension, and battery design remain 100% proprietary. That’s core Rivian DNA and not part of the deal.
  • Infotainment System: Rivian’s Android Automotive–based UI (camp mode, pet mode, etc.) stays with Rivian. It's possible for VW to have similar features, but they will have to build that on their own. It won't be naturally inherited from Rivian.
  • Autonomy Stack: Rivian’s machine-learning-based driver assistance is not included. The joint venture will provide the hooks (zonal ECUs can connect to radars, cameras, sonars), but VW has to build or buy their own ADAS system.
What This Means for the Future of VW Vehicles:
This isn’t just about cleaning up wiring. It’s about the future of software-defined vehicles.
  • With a zonal architecture, pushing OTA updates is straightforward. Instead of updating 15+ random third-party modules, they'll update a handful of zonal controllers co-developed with Rivian.
  • VW is paying $5.8 billion for this, because they’ve seen Tesla and Rivian thrive with OTA updates while legacy OEMs have stumbled. This deal is VW’s shortcut to catching up.
  • Rivian benefits massively too: scale, validation, and cash flow to accelerate R2 and beyond. It's likely R2 will benefit from some of the work the JV is doing, but R3 and beyond will DEFINITELY benefit.
In a Nutshell -
Included:
  • Zonal architecture (ECU designs + software + protocols)
  • Vehicle network and OS foundation
Not included:
  • Motors, batteries, chassis engineering
  • Infotainment and Rivian Features
  • Rivian’s proprietary ADAS/autonomy stack
My take: This is a smart move for both companies. VW gets to leapfrog years of messy architecture redesign. Rivian locks in billions in funding, credibility, and a big partner. Most importantly, Rivian keeps the “soul” of its vehicles — the powertrain, the autonomy stack, and the customer-facing software — fully proprietary.
What do you all think?
Rivian should give them the Apple Music app as a subtle form of corporate sabotage:giggle:
MountainBikeDude
Vancouver
I see you've had your cup of coffee this morning. Already in fine form 🤪
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
What VW DOES Get
What VW DOESN'T Get
In a Nutshell -
Included:
Not included:
Didn't need to watch the video, your write-up was plenty detailed enough.
I'm going to keep this post saved so that every time someone links a video or article saying "XXXX's infotainment is gonna be so much better now" has the actual, PROPER info attached to it.
What VW DOES Get
What VW DOESN'T Get
In a Nutshell -
Included:
Not included:
That’s pretty much it and is aligned with information Rivian and RJ have shared numerous times. Now, a bit of speculation, VW has a battery arm called PowerCo. And PowerCo has a licensing agreement with QuantumScape for solid state cells, which has been independently verified recently. This is among one of the SS front runners outside of China. When it’s viable for the industry to pivot, Rivian could tap into that connection. If they had this in mind, the decision to form JV is wise beyond all points above.
mpshizzle
mpshizzle
Utah
If all that comes to fruition that would be INCREDIBLE
Given what MB and BMW rolled out recently and will be hitting dealers next year… Rivian has to know they are behind on range and fast charging (800V). I think that needs to happen before the shift to SS. Amazing if at same time but I doubt PowerCo is ready on cell production.
MountainBikeDude
Vancouver
Just to add to this thread. This video from OOS while at the Scout reveal does a good job of summarizing the JV to date. Starts at the point of interest.
There have been rumblings in the background that the JV will have broader implications, but we only have what has been publicly talked about by each company.
portdirect
Missouri
Blinkenlight Hearder
Doesn't GET is not the same as wont build - they are 100% building a joint infotainment system where the difference will be in the skin applied above it. Also expect the audio platform to be shared between VW and Rivian moving fwd - as well as many aspects of ADAS etc (perhaps not the actual model driving it, but the camera systems/sensor fusion etc is intended to be a common platform).
Overall I don’t think it’s right to think of this as somthing VW is paying billions for - they are investing billions into future software development and it’s been seeded with some Rivian IP.
mkhuffman
This is exactly what I was thinking and I really hope this is what happens.
I purchased some QuantumScape stock a whole ago and it is now up over 50%. I am holding on to it for the long run, hoping it explodes to 100x or 200x what I paid. 🤞
Regardless, I am even more hopeful a new version of the R1 has it. Could it be three years away? Doubtful, but wouldn't it be awesome if the Gen3 R1 had a 200kWh SS battery? One can dream.
hammick
Stormy
Montana
Can't believe how polished that UI was for a prototype . Maybe Rivian can implement some of that without violating the JV.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
I got to participate (and even got paid) in reviewing and fleshing out the off road parts of the VW interface. It was phenomenal in the early versions around March or so. I’m very optimistic about a Scout truck replacing my Rivian.
That’s good for all of us.
