TexasBob
Houston
This is a longwinded post but the short version is I figured it was pretty straightforward to build a decent model to predict highway range. So I got together with Claude and Gemini and we did. I did this for another reason but then ran R2 through it and thought you folks would find it useful. The result is this: an AWD Launch Edition with 21" road tires should deliver ~250 miles of highway range at 70mph sea level in good weather (note Out of Spec at higher altitude add ~20 miles). This is pretty competitive with Model Y (Motortrend just benchmarked it at 252 which is consistent with the model).
I've summarized the model details below and attached the full writeup in pdf. It is sensitive to input data so that as always is the key caution.
EDIT - Updated the EPA estimate to 335 from 330 (no impact on model)
Rivian R1T R1S R2 Highway Range at 70MPH = ~250 Miles (Modeled) Screenshot 2026-04-26 at 10.49.50
Here is the modeled 2026 Model Y for comparison (AWD 20" wheels)
Rivian R1T R1S R2 Highway Range at 70MPH = ~250 Miles (Modeled) Screenshot 2026-04-25 at 22.42.50
The Calculation
1 Mechanical Power Requirements
The mechanical power required at the wheels to sustain a constant velocity is the sum of aerodynamic drag power and rolling resistance power.
Aerodynamic drag power, which overcomes air resistance, scales with the cube of velocity:
P_aero = ½ × ρ × v³ × Cd × A
Rolling resistance power, which overcomes tire deformation and surface friction, scales linearly with velocity:
P_rr = m × g × Crr × v
Where ρ is air density (kg/m³), v is velocity (m/s), Cd is the drag coefficient, A is the dynamic frontal area (m²), m is total vehicle mass including payload (kg), g is gravitational acceleration (9.81 m/s²), and Crr is the rolling resistance coefficient.
2 Electrical Power Draw
The total draw from the battery pack adjusts the mechanical power requirement for drivetrain efficiency and adds the constant auxiliary power demand:
P_total = (P_aero + P_rr) / η + P_aux
Where η is the hardware-specific drivetrain efficiency and P_aux is the baseline auxiliary power draw for thermal management, computing, and HVAC systems.
3 Range Calculation
The consumption rate in Wh/mi is derived by dividing total power by velocity and converting units. The theoretical range is the usable battery capacity divided by this consumption rate, multiplied by the 0.97 real-ideal adjustment factor:
Consumption (Wh/mi) = (P_total / v) × 0.44704
Range (mi) = (E_bat × 1000 / Consumption) × 0.97
The 0.97 adjustment factor (3% haircut) was derived empirically from calibration against multiple benchmark vehicles and accounts for BMS management overhead, parasitic losses in power distribution, and minor regenerative braking losses during speed maintenance that are not captured in the steady-state power equation.
The Validation
The model was validated against two independent benchmark datasets: Arena EV (controlled-speed road tests at 56 and 81 mph in Europe) and Out of Spec Reviews (70 mph highway range tests in the United States). The steady-state physics model described in this paper provides a reliable, transparent, and validated method for predicting highway range of battery electric vehicles at constant speeds of 70–81 mph. The model achieves ±3–5% accuracy against independently measured benchmark data when environmental conditions (altitude, temperature) are accounted for.
The Critical Input Variables
The precision of the model depends entirely on the rigorous extraction of its physical constants. Generic baselines are avoided in favor of platform-specific hardware tagging and dynamic geometric extraction.
1 Aerodynamic Variables (Cd and A)
The drag area (CdA) is the primary determinant of high-speed range and requires the most critical refinement.
Drag Coefficient (Cd) is sourced from published manufacturer wind-tunnel data where available. Where manufacturers do not publish Cd (notably Rivian), values are estimated from independent CFD simulations and cross-referenced against range test results. The sensitivity of range predictions to Cd uncertainty is documented for each such vehicle.
Dynamic Frontal Area (A) is calculated from published vehicle dimensions rather than static bounding-box estimation. The formula subtracts the ground clearance void from the gross bounding box, then applies a vehicle-class fill factor:
A = [(Width × Height) − GC × (Width − 2 × TireWidth)] × FillFactor
The ground clearance void calculation excludes the area beneath the chassis where air passes freely, while retaining the tire footprint in the blocking profile. The fill factor accounts for greenhouse taper, fascia radius, and body sculpting that reduce the actual air-blocking area below the rectangular envelope.
A key finding of this research is that the fill factor for electric vehicles collapses to two categories rather than the three or four typically used for ICE vehicles. Because every EV designer optimizes the frontal profile for efficiency (CdA equals range), even vehicles that appear boxy from the side — including the Rivian R1S, Tesla Cybertruck, and Chevrolet Silverado EV — have heavily sculpted frontal profiles. The “boxy SUV” fill factor category that exists in ICE vehicle analysis does not exist in EV analysis.
2 Drivetrain Efficiency (η)
Drivetrain efficiency is tagged according to the specific electrical architecture of the vehicle, reflecting the combined efficiency of inverter, motor, and gearbox at steady-state highway operation. Generic industry averages are rejected in favor of architecture-specific multipliers.
Examples
800V SiC + Permanent Magnet
0.92 – 0.94
BMW Neue Klasse, Lucid, Porsche PPE, Hyundai E-GMP
Optimized 400V SiC
0.90 – 0.91
Tesla Model 3/Y/S/X, CT, Rivian R2
Standard 400V Silicon IGBT
0.88 – 0.89
Rivian R1, legacy GM/Ford platforms
3.3 Rolling Resistance (Crr)
Rolling resistance is tagged according to the physical tread pattern and compound of the specific tire fitted to the vehicle, not a generic vehicle-class assumption.
Examples
Optimized EV Road Tire (19–20")
0.0080 – 0.0085
Michelin LTX, Pirelli Scorpion Zero, Tempest
Performance / Sport Summer (21"+)
0.0090 – 0.0100
Eagle F1 Asymmetric, Pilot Sport EV
Aggressive All-Terrain
0.0120+
Pirelli AT Plus, BFGoodrich Trail-Terrain
3.4 Auxiliary Power (P_aux)
Auxiliary power represents the baseline thermal, computational, and HVAC load at steady-state highway conditions in the normalized 15°C environment. Two tiers are used: 1.2 kW for highly integrated heat pump systems (Tesla Octovalve architecture), and 1.5 kW for standard EV thermal management platforms.
3.5 Battery Capacity (E_bat)
The model uses BMS-accessible usable capacity, not gross pack size. Where discrepancies exist between manufacturer specifications and measured data (e.g., from OBD scans or drive-to-zero tests), the measured value is preferred. The Out of Spec Reviews dataset provides independently measured usable capacities for many vehicles and is used as the primary reference where available.
Rivian R1T R1S R2 Highway Range at 70MPH = ~250 Miles (Modeled) Screenshot 2026-04-25 at 21.49.34
R2dreamer
Hutchinson Island, FL
2005 Honda CRV, 2014 Lexus RX450h
The Calculation
3 Range Calculation
The Validation
Examples
0.92 – 0.94
Optimized 400V SiC
0.90 – 0.91
0.88 – 0.89
Examples
0.0080 – 0.0085
0.0090 – 0.0100
0.0120+
Thanks, nice work indeed. So I guess the EPA testing takes lower speed in town type driving more into account then a lot of highway driving.
huntzman
VA
Kia Sorento PHEV
May be a dumb question, but how do aero considerations in other parts of the vehicle that aren't the frontal area (A) play into range? For example, on the R2, the roofline swoop towards the back, and hiding the rear wiper both contribute to range increase. Do improvements like those lower Cd? If so, what is Cd anyway?
NoMoreGas71
Atlanta
Tesla Model S, Lexus TX 350, Chevy Trax
We are splitting hairs here, but the EPA range is 335 miles on the R2, not 330.
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
cd stands for 'Coefficient of drag'. It's a measure of how slippery your vehicle is. A loner number is better (although it's always expressed as 0.xx)
I think it can be plugged into some sort of equation, but I don't know which one(s) or how.
Gen(R3)Xer
Ohio
Every little bit counts from the rear roof spoiler, the under carriage spoilers (front and rear), the rounded rear quarter panels, any air intakes, and the wheel designs.
Cd, or coefficient of drag, quantifies the drag or resistance of an object moving through the air or water. The lower the number the better the range. That’s an over simplification of course. It depends on a lot of other factors, like battery size, weight, drive train efficiency, horse power, etc.
For Rivian it was all about balancing these things in the R2, which I think has a Cd of 0.28. This is compared to the R1T that has a Cd of 0.30. I’m not sure about the R1S. These are very boxy vehicles and in the case of the R1s tall vehicles.
Anyway, Rivian did an excellent job of balancing all of these things with the R2 while still retaining the form factor people like about the R1S.
R2dreamer
Yes based on what the author said he evaluated the starting point for the calculations should be 335 which may give slightly better results versus the MY. the charts should be updated.
TexasBob
TexasBob
Houston
I know it probably got lost in the long post but cd is a variable in the P_aero number. It is area x cd.
The CD I used in the model is 0.28 for the R2. If that turns out to be optimistic it will have a negative impact. The model Y is 0.24 which is slightly higher than Tesla's marketing number but consistent with third party tests.
TexasBob
TexasBob
Houston
This makes no difference to the model. It does not use the EPA numbers at all.
mkg3
R1S, Model 3, Outback, Artura
The back sloping is done to reduce the base drag. The reason most EV SUVs or crossovers have coupe like rear (e.g., Model Y) is to reduce the base drag, which is a huge contributor to the total vehicle drag. Lower rear diffuser on some vehicles (especially sports cars) is also done to clean up the base drag. Rivian has a paten on deployable rear diffuser for the rear (presumably to retract for off road and deploy for higher speed on freeways)
Whatever the Cd is for any vehicle, the drag force increases at added velocity squared so going 15mph (22 ft/sec) faster will increase the incremental drag force by a factor of (22 x 22 =) 484 multiplier.
The OP claims Cd of 0.28 for R2. Maybe so.
LongRoadHome
Clayton
Overland Park, Kansas
Structural engineer
So, with this information, shouldn’t the trip planner be able to give recommended speeds, based on charging times and locations, that would get you there the fastest? Sorry, I take possession next week so I haven’t used navigation yet.
TexasBob
TexasBob
Houston
It is always *faster* to drive faster and burn more electricity and stop more often. The a fast charging session is adding electrons at a rate of 250 - 550 miles per hour. You will never save *time* by driving slower. You will definitely save a lot of energy and go father before stopping.
And yes, OEMs know all this with great precision and can produce a highly accurate chart for any vehicle (the math is simple it is the inputs that are difficult to get). Grumble grumble.
However... no OEM wants to advertise a ~250 mile 70 mph highway range on an EPA official 320+ mile vehicle. So they do not give out this data. Rivian knows exactly what this curve is for the R2. And btw, the energy shifts significantly with temperature (warmer is better) and altitude (higher is better) as those things matter quite a lot at highway speeds where it is mostly about pushing air. Except in the rain and then on a wet road suddenly rolling resistance jumps significantly and can whack your range by 10-15% even while dropping speeds.
tivoboy
Paul
Palo Alto, CA
M3
The only caveat counter to this statement is it needs to be at SOC that are less than about 75%. Someone did the math with Tesla‘s many years ago and as long as SOC is less than 75% then the absolute statement “it’s always faster to drive faster and stop more frequently“ sort of holds up.
I don’t think enhanced trip planners completely take that into context, other than possibly a better route planner, which Rivian does utilize to some extent for their in Car, algorithm and metrics and projections and recommendations.
