800v charging capability, when?
Kaiju
There's a few things worth talking about with respect to global competitiveness. The first is that chasing the bleeding edge is not actually the key to global competitiveness. It's better to be efficient first unless you're selling to people where the price isn't the main concern. That doesn't apply when you're selling 500k vehicles a year.
Second though is that people don't seem to realize that there's a lot more going on with respect to 800V and 400V architecture and selection is quite a lot more complicated than just being ahead or behind an arbitrary curve. One consideration is related to vehicle and battery size. Small vehicles which have relatively small batteries see more benefits from 800V systems because they don't require monstrous DCFC ratings to charge quickly and if they were amperage-limited by design then they can accept more power from existing chargers.
Larger packs that already hit the limits that chargers can deliver see less of a benefit. People talk about loss and efficiency but I'd also point out those are engineering decisions rather than architecture consequences. You can make a 400V system more efficient than an 800V system, depending on who cuts corners where. That's because resistance and losses are related to materials and the straight-up cross-section of conductors. Switch to aluminum to save money? More resistance. If you make the wires smaller in an 800V system you increase resistance. You can save money maybe by doing so, but you're erasing some of the supposed efficiency gains.
For example if you take a large wire and reduce its size so its max current rating decreases by half, its cross-section is reduced to about 55% and resistance per unit length increases by more than 3x. You've cut current by half for the same power but...uh, you haven't actually made a more efficient system. It's actually worse. But then that relationship is not linear across wire sizes. It changes in favor of higher voltage as the wires get smaller because ampacity ratings are based on the temperature ratings of insulation.
If you use the same size wire in an 800V or 400V system, yep, definitely more efficient because it's straight up less current over the same resistance. But then you're not saving any money and are in fact spending more because higher voltage is higher cost. That's one reason why 800V isn't actually cheaper if you're chasing the extra efficiency. And then...you can brute force it on a 400V system by just making stuff bigger to reduce resistance. Is that optimal? Maybe not, but it might still be cheaper depending on how much more copper costs vs that 800V inverter.
In marketing terms yeah, you can sell someone on 800V because it's a bigger number and bigger numbers are better! Unless they're charging times. Since someone mentioned the Silverado EV and charging, I suppose it's worth mentioning that one of the reasons it can take more kW in a shorter span than a Rivian is because the battery pack is gigantic, a full 50% bigger than a max pack. It's not neccessarily because 800V is that much better.
icy1007
Jason
Ohio
Considering R1S Tri Motor
Software Developer
All signs point to the R2 charging at 400v. Same with R1.
So, the question is, when will Rivian provide 800v charging capability?
When looking at the totality of the EV tech landscape, it feels like max 400v charging is becoming outdated really fast.
Maybe when public infrastructure goes above 400v.
krockett
FJ Cruiser
Yes, but it's another feature "they" have and Rivian doesn't.. just like CP and AA. Eventually, when buyers sit down and (hopefully) make a list of features one vehicle offers compared to another, at one point one vehicle stands out having more features than another vehicle. No 800V charging, no AA/CP, no Vehicle to Home, no local repair facilities, etc... start falling too far behind and soon you'll be out of the competition.
Don’t care about CP/AA or V2H either 😉
hammick
Montana
I'd like to to know how the Lucid Gravity can charge super fast at a V3 Supercharger but the Hyundai/KiA 800v vehicles cannot. I would not be a happy camper if our Rivian maxed out at 123kw at Superchargers.
DuoRivians
R1T, R1S
Lucid and GM have the ability to switch between 400v and 800v, by dynamically changing their battery charging configuration between parallel or serial circuit.
Parallel gets 400v. Serial gets 800v.
Hyundai can only do 800v, but it uses its electric motor to upscale a 400v to 800v. This upscaling isn’t that efficient, so that’s why they get low kw on a 400v charge
SeaGeo
Brice
Xc60 T8
I disagree with this logic here. If you have a ~400v pack that charges at 500A (e.g. 200kw) with a capacity of say 50kwh, it would in theory take 15 minutes to charge it. If you scale that pack up to 200kwh, it takes an hour. If the charger is a 350 to 400kw charger that only offers 500A, both the small pack and large pack are hitting the amperage limit and stuck at 200kw. However, if the large pack is on an 800v setup and can still take 500A (e.g. 200kw), then it's going to pull the maximum charger power, significantly reducing the charging time.
Additionally, the 800v system helps with the large number of chargers with cables that are current limited (looking at you Chargepoint) that require 800v systems to fully utilize the charger.
The only "public" infrastructure that isn't 800v are Tesla chargers. Virtually all other DC chargers accommodate both voltage ranges.
SeaGeo
Brice
Xc60 T8
I have charged my Hummer at V4 and get the same charging curve as a V3.
I'm pretty sure you're charging at a V3 cabinet with a V4 dispenser, so your Hummer was charging at 400v instead of 800v.
SeaGeo
Brice
Xc60 T8
Small correction. With the Gravity, Lucid is doing the same thing as Hyundai. They are not doing any pack voltage switching. They're using the motors to bump the voltage up.
On the air they use the wunderbox to scale the voltage.
hammick
Montana
I haven't researched why all EVs aren't 800v architecture. I do know that a good 240v well pump might cost a little more than the 120v version but you save big time on the smaller gauge wire so it always makes sense to go higher voltage.
I'd like to know what makes a 400v EV cheaper to produce than an 800v EV. Certainly the 800v version would allow for smaller gauge wire.
icy1007
Jason
Ohio
Software Developer
Tesla accounts for the majority of DC fast chargers. They are the gold standard of the industry. I don’t really see Rivian changing to 800v until Tesla does.
SeaGeo
Brice
Xc60 T8
I'm not sure that they do actually exceed CCS ports in overall. The SC aren't really "the gold standard," for the chargers themselves. Their network as a whole is, sure. Regardless, there are a very large number of higher powered, high voltage chargers throughout North America.
Tesla changed to 800v with the cybertruck, and is rolling out V4 cabinets this year. So...
Hereforthesnacks
West Coast
Ford Bronco
I think Hyundai/Kia have realized that they’ve over engineered some of their models and are now releasing more affordable models with only 400V architecture (think: EV2, 3, etc). It’s cheaper and more profitable for them.
No. Kia is sticking with the 800V architecture. It’s not over engineered…. Plus you can’t read get a fully loaded family hauler for $65k out the door. It’s a very competitive price for that size car.
MidnightRivian
sOOn
probably with R3 launch / R2 Gen 2 refresh
Gen(R3)Xer
Ohio
