Air-Conditioning not cold enough - Will I be charged if it's "within spec"?
White Shadow
Thomas
NJ
Jeep & Audi
SP
Part of the reason for that is your 2004 Tahoe is R134a refrigerant. EPA regulations sunsetted R134a due to its GWP (Global Warming Potentional). All auto manufacturers now use R1234yf. Depending on who did the study, R1234yf is 5% to 20% lower performance compared to R134a.
When manufacturers switch to a new refrigerant, they also change other components in the system so that the cooling efficiency remains within spec. That said, my Jeep uses R1234YF and the A/C is so cold that I can't leave it on max cool for long even on a 100 degree day.
White Shadow
Thomas
NJ
Jeep & Audi
SP
Keep in mind that temps in the A/C vents mean almost nothing without also considering ambient temperature. As a general rule of thumb, your vehicle should be putting out about 20 degrees cooler air than ambient temps.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
That would really suck if it were true, luckily it's not. I'll be in a place that's 115 today, you think my AC will be blowing 95? LOL.
ChadS
Chad
Virginia Beach
Cyber Security Director
Thats where recirculating air versus outside only comes into play.....
SwampNut
Carlos
Peoria AZ
Geek
Actually, it is. I used to work on A/C systems. Research Delta T and educate yourself. HVAC isn't magic.
I have an MVAC certification. You absolutely will not get 90 degree air when it's 110. You will get 45-50. I just had the Rivian in for a full AC evac/charge and the tech left the thermometer in the vent. Under 50 while it was over 100, not on recirc (car was 150 inside anyway).
SwampNut
Carlos
Peoria AZ
Geek
Today, my car's inside temp will hit 145 and the fans will kick on to prevent it going higher. It will be 110 outside. How exactly do you think the interior gets to 75 in less than five minutes?
White Shadow
Thomas
NJ
Jeep & Audi
SP
Yup, recirc is a factor. So is humidity. But generally speaking, if you have a 20 degree differential, the A/C system is probably working just fine. Too many people think that they should see 40F at the vent and that's just not the case most of the time.
White Shadow
Thomas
NJ
Jeep & Audi
SP
Cool story. Unfortunately, there's not am automotive A/C on Earth that will output 45-50 degree air from outside ambient over 100. Sorry, not possible. The math just doesn't math.:)
SwampNut
Carlos
Peoria AZ
Geek
There's not a single automotive AC on earth that will be limited to a 20 degree differential when working correctly.
White Shadow
Thomas
NJ
Jeep & Audi
SP
Do you not understand that recirc is needed to allow the system to continue to drop interior temps when the heat load outside is high? This should be fairly obvious, no?
White Shadow
Thomas
NJ
Jeep & Audi
SP
I never said that. Don't put words in my mouth.
White Shadow
Thomas
NJ
Jeep & Audi
SP
Hey Swampy, maybe you should post a video and prove me wrong. Wait or your 110 degree day and then throw a thermometer in your vent and show us the temp and video it as it drops. I'd love to see that.
When manufacturers switch to a new refrigerant, they also change other components in the system so that the cooling efficiency remains within spec. That said, my Jeep uses R1234YF and the A/C is so cold that o can't leave it on max cool for long even on a 100 degree day.
Some components have to be changed such as the capillary tube or expansion valve. Other components don't have to be changed but should be changed if the manufacturer wants to keep the same cooling capacity. But they also might choose to not change components due to space, production or other non-technical (lol financial) reasons and deem the decreased capacity as the new spec. I have read discussion in the Dodge community that when Dodge moved to R1234YF they did not change the compressor, evap or condensor coils, which would result in lower cooling capacity.
