Always on fog lights?
sub
Rivian R1S, Tesla Model 3
You mean startling a deer with bright lights so that you’re sure you can hit?
By the way to answer your question, it’s illegal in pretty much all states (either written plainly in the law or creating lumen and direction limitations). A quick Google search will tell you but here is some info:
LIGHT BAR LAWS BY STATE
AlabamaOff-roading lights limited to two glare-free cowl or fender lamps.Alabama Legal Information
AlaskaThe front of a vehicle is limited to four lights. No part of a high intensity light can strike the road.Alaska Legal Information
ArizonaAny light greater than 300 candlepower (3,771 lumens) must be directed so that no part of the beam strikes the road 75 feet from the vehicle.Arizona Legal Information
ArkansasNo auxiliary driving lights may be used on pubic roads.Arkansas Legal Information
CaliforniaWhen on public roadways, off-road lights must be off and covered with an opaque cover.California Legal Information
ColoradoAuxiliary lights are limited to two, and the beams must be directed to the left side less than 100 feet away from the vehicle.Colorado Legal Information
ConnecticutNo more than four lights on the front of a vehicle. They cannot exceed 300 candlepower (3,771 lumens).Connecticut Legal Information
DelawareAllows two spotlights and two headlights. Light bars must be off while on the road.Delaware Legal Information
D.C.All lights greater than 300 candlepower (3,771 lumens) must be directed so no part of the beam hits 75 feet away from the vehicle.D.C. Legal Information
FloridaOnly four lights are allowed in front of a vehicle, and must adhere to existing light laws.Florida Legal Information
GeorgiaOnly one spotlight, not to be aimed at any approaching vehicle. One "auxiliary driving light" is allowed but must be mounted between 16 and 42 inches from the ground.Georgia Legal Information
HawaiiLights are not allowed to exceed 2,400 candlepower (30,168 lumens). Light bars must be turned off on roads.Hawaii Legal Information
IdahoIf any of the front lights have a light with greater than 300 candlepower (3,771 lumens), then only four lights are allowed.Idaho Legal Information
IllinoisNo more than four lights on the front of a vehicle may be lit. All lights must be dimmable and aimed away from other drivers' eyes.Illinois Legal Information
IndianaOne auxiliary driving lamp is allowed, but must be mounted between 24 and 42 inches from the road's surface.Indiana Legal Information
IowaAny bright light must be directed away from the eyes of other drivers. Only three auxiliary driving lamps are allowed on a vehicle.Iowa Legal Information
KansasAll lights must be directed so that no part of the high intensity beam strikes the roadway more than 75 feet out from the vehicle.Kansas Legal Information
KentuckyIllegal to drive with LED light bars turned on.Kentucky Legal Information
LouisianaIllegal to drive with LED light bars turned on.Louisiana Legal Information
MaineNo auxiliary light can be brighter than the standard lighting equipment.Maine Legal Information
MarylandNo more than two auxiliary lamps mounted between 16 and 42 inches above ground level.Maryland Legal Information
MassachusettsIllegal to drive with LED light bars turned on. Strict regulations on all aftermarket lighting.Massachusetts Legal Information
MichiganNo more than four forward facing lights.Michigan Legal Information
MinnesotaMay have up to two auxiliary driving lamps between 16 and 42 inches above a level surface.Minnesota Legal Information
MississippiTwo auxiliary driving lamps allowed, but must be mounted between 12 and 42 inches above a level surface.Mississippi Legal Information
MissouriUp to three auxiliary driving lamps mounted between 12 and 42 inches above a level surface.Missouri Legal Information
MontanaLight bars may not be used on public roadways.Montana Legal Information
NevadaTwo auxiliary lamps mounted between 16 and 42 inches above a level surface.Nevada Legal Information
New HampshireUp to three auxiliary driving lamps mounted between 12 and 42 inches high.New Hampshire Legal Information
New JerseyMay use a light bar as long as it is low profile and sits lower than the headlights.New Jersey Legal Information(PDF Download)
New MexicoOne auxiliary driving lamp mounted between 16 and 42 inches above the ground. Must be able to be turned off at least 500 feet from approaching vehicles.New Mexico Legal Information
New YorkWhile not technically illegal, all auxiliary lights cannot exceed 32 candlepower (402 lumens). There are no light bars made with less than 32 candlepower.New York Legal Information
North CarolinaLight bars must be off while driving on public roads.North Carolina Legal Information
North DakotaNo part of the light can hit the ground 75 feet from the vehicle.North Dakota Legal Information
OhioNo more than five front-facing lights. No high intensity beam may strike the roadway 75 feet from the vehicle.Ohio Legal Information
OklahomaOff-road lights may not be used on roadways.Oklahoma Legal Information
OregonOff-road lights may only be used off-roads.Oregon Legal Information
PennsylvaniaOff-road lights must be off and covered while on public roads.Pennsylvania Legal Information
Rhode IslandAll lights with more than 300 candlepower (3,771 lumens) must be directed so they don't hit the roadway more than 75 feet in front of the vehicle.Rhode Island Legal Information
South CarolinaAll lights with more than 300 candlepower (3,771 lumens) must be directed so they don't hit the roadway more than 75 feet in front of the vehicle.South Carolina Legal Information
South DakotaAll lights with more than 25 candlepower (314.25 lumens) must be directed so that no part of the beam hits the level surface 50 feet in front of a vehicle.South Dakota Legal Information
TennesseeNo more than two auxiliary lights allowed, and no portion of the beam may be directed where it can strike oncoming drivers.Tennessee Legal Information
TexasTwo auxiliary driving lamps are permitted, but must be mounted between 16 and 42 inches above a level surface.Texas Legal Information
UtahAny light with greater than 300 candlepower (3,771 lumens) must be directed so that no portion of the beam strikes the roadway.Utah Legal Information
VermontAftermarket lights must be DOT approved.Vermont Legal Information
VirginiaAny lights mounted higher than factory headlights must be covered. May have 2 uncovered lights in addition to headlights. Uncovered lights must be set to turn off if brights are turned on.Virginia Legal Information
WashingtonTwo auxiliary lights are allowed, but must be mounted between 16 and 42 inches off the ground.Washington Legal Information
West VirginiaAll lamps mounted higher than 42 inches off the ground must be covered.West Virginia Legal Information
WisconsinNo more than 4 forward facing lights.Wisconsin Legal Information
WyomingLight bars are not legal on public roadwaysWyoming Legal Information
None of those laws would apply to fog lights. Fog lights are not the same as light bar.
AxelR
Axel
Posting OFF-ROAD light regulations doesn't really apply to OEM fog/driving lights.
You guys need to read the rest of the thread to know why I put this here. That being said you’re correct, it was not the principal subject of this conversation.
Overall just pointing out that people don’t love being blinded by others when driving.
Maybe Toyota doesn’t have DRLs and uses. Fog lights instead?
CharonPDX
Charon
Cascadia
InfoSec Geek
Toyota delivers vehicles in Oregon that allow you to have your fog/driving lights come on automatically when low-beams are on.
And they shouldn't.
CommodoreAmiga
INACTIVE
INACTIVE
I owned a 2005 Toyota Tundra that had DRL and fog lights. Fog lights switch could be turned on or off, and when "on" were linked to the low-beams. Setting persisted between engine cycles, too. DRLs couldn't be disabled.
BourboNole
Orlando, FL
Forest Green/Forest Edge R1T on 21s
Oregon does. Oregon treats fog lights the same as using your high beams. As do many states.
Not from what I could find in statutes. Oregon requires that "within 500 feet, the driver must use a distribution of light or composite beam so aimed that the glaring rays are not projected into the eyes of the oncoming driver." The DOT has issued advisories that fog lights must be dimmed for oncoming traffic, but the statutes don't seem to back that up outside of the vague (and likely unenforceable) requirement that "glaring rays are not projected into the eyes of the oncoming driver."
sub
And they shouldn't.
Why not? Please provide law/regulation to back up that claim.
If you are referring to Oregon Revised Statutes Oregon Vehicle Code § 811.515, I cannot find in that would forbid 24/7 use of fog lights.
  • It forbids the use of more than 4 headlights. 2 normal lights + 2 fog lights = 4.
  • It forbids spotlights, which would not include a fog light.
  • It forbids lights placed higher than 54" off the ground. Fog lights are closer to 12" than 54".
  • It also forbids some lights that project a beem more than 75 feet from the vehicle. The procedure for aiming a fog lights is to park 25 ft from a wall and adjust the lights so that the beam is 4" up the wall. As long as the light bulb is at least 12" off the ground. 12"/4" x 25' = 75'. If the light bulb is located higher than 12", then the beam would make it even less far. So a fog light that has been adjusted to this standard will not project more than 75 ft. The choice of 75' in this section, when that is the exact distance that fog lights are calibrated to, seems to imply they were specifically trying to say that fog lights are OK.
So none of those apply to fog lights.
Lmirafuente
Lionel
Gen1 R1S, Audi Cabriolet
can someone take a pic of what the front and especially the rear fog lights look like on?
thanks in advance!
Olsonsolar
Illinois
enjoying life
Probably should install a 48” light bar too and leave it on all the time. Not annoying at all for other drivers ?
Rivian should program them so they automatically switch off if there is oncoming traffic. Most people don’t use them because they are effective but because they think they look cool. Never minding blindly oncoming traffic.
jeeden
Jeremy
Northern VA
Project Manager
Came here looking for this, is the guide the official way to submit requests for features?
All the SUVs I have owned recently will allow you to have auto headlights with or without the fogs and then when the high beams come on manually or automatically it turns the fogs off.
