Clunking noise?
All_electric_Seattle
Dan
Tesla Model Y, R1T
Construction
That was the Google voicemail transcript so it might sound a little computer like...
shap
Austin,TX
BMW 45e, R1T
Hello,
I do not know if anyone can help to understand the knocks I have only when I accelerate and decelerate (mostly pronounced when driving slow, but exist at any speed). I have attached the video with the sound:
Jonger1150
Jon
Howell, MI
Nerd
The service center will know. This is a common issue.
shap
Austin,TX
BMW 45e, R1T
There are several threads about this. A continuing problem.
Thank you,
I just try to understand if it is half shafts (and there is no real solution), suspension or something else. I do not want to force SC to start replacing parts if the outcome will be the same. By doing this they probably will break my alignment (that took them 3 times but they finally nailed it).
Jonger1150
Jon
Howell, MI
Nerd
Thank you,
The chirps and hard clunks are Fixable.
Replace jounce lines removes squeaks
Replace dampers removes hard clunks
There's no fix for the half-shafts beyond greasing the splines. It will give you 3000 miles of reduced sound.
The dampers and jounce lines have new parts.
shap
Austin,TX
BMW 45e, R1T
Just to update the team - I just went to Austin SC (they are always super), talked to the mechanic, we took other QM for a test - same (or almost) knocks exist as well when you accelerate/decelerate. He basically said - look, we can improve it a bit, but it is what it is. This is a design flaw, and while functionally it will work fine, the noise should not be there for a 90k car.
So I just decided to close my ears on this and continue to use R1T.
P.S
I think I will get back to the BMW brand going forward - just drove iX - and BMW did amazing work, no knocks, or any other sound other than a pleasant driving experience :) 2023 goes for 60k already ...
DaveA
Rivian R2 Launch Edition
P.S
I can modulate it away by feathering the accelerator, but yeah, same story I have received from the Austin SC. It is what it is, greasing quiets it for 100 miles, and back to status quo. Did you happen to drive a dual motor to see if it is similar?
shap
Austin,TX
BMW 45e, R1T
No, I did not try dual - my miss. Next time I am there I will ask them.
