Driver + Regen Braking
srkz
So don't use Driver + going downhill.......got it! how about "simple" cruise control??
Same thing. It's not just down hill, it's any time the vehicle needs to slow you down while you're in any kind of cruise control mode, so if a car is in front of you, if you go down hill, if you lower the set speed because the speed limit changed, etc.
I was testing with "simple" cruise control because you can't actually use Driver+ on random neighborhood streets haha.
Kidentist
Carlitos way
PNW
Audi A3, Cayenne E-Hybrid, R1T DM Std.+
Mouth Janitor
Well that sucks...... :(
kingofheaven
Jack
FL
2025 R1S DM Standard Gen2
wow, this would be pretty bad.... We'd have to get break pads/rotor replacement which I never had to do with any of my teslas.
By the way, with the new update where can I find this break regen assist setting?
Wing
James
Ottawa
I posted this on Reddit about a month ago. Nobody believed me.
Cruising on a flat highway following a car the display will show yellow (formally blue) and the brake pedal will move and slow you down.
It's using the friction brakes to adjust speed while simultaneously applying power. I felt it many times while on a trip.
As a result I try not to follow cars within the following distance I'll either pass them or shut cruise off because there is no "regular" cruise available that just maintains a damn speed... My biggest gripe with the vehicle.
srkz
It does actually have dumb cruise control, but only when towing.
Wing
James
Ottawa
Yes then it's really dumb. No Blindspot monitoring even!
suprteck
Anthony
Tesla Model 3, Rivian R1T
Mechanic
Just noticed this too. When using driver + with brake assist off. Put my foot under the brake pedal and I could feel the brakes being applied anytime there was a change in speed. I will not use drivers + unless I really have to. Now I need to check my brake pads when rotating my tires.
R1Sky Business
R1Sky Business
The adventure continues
CBRacerX
Ugh. I feel our pain about this should be communicated to the manufacturer.
Riviaenz
Not enough meaning a sudden braking scenario....
No, it blends in braking for sure. It’s why the rear brakes wear out faster than the fronts.
beatle
Springfield, VA
This sounds pretty lousy. It has the potential to significantly reduce range in hilly areas.
