Efficiency Has TANKED
Jayhawkeye
Jayhawkeye
Kansas City
Ford Expedition, Jeep Grand Cherokee
Software
I don't think an EV is for you dude.
Huh? We love it but are terribly bummed we have lost 50 percent range in the cold. Should we not worry about that? I’m just here to help others out with my experiences given we are all in the same boat.
Redline
Edina, MN
I guess I'm more surprised you didn't know the loss of range with EVs in these temps.
Also, as others have said, short rides are the absolute worst in this weather.
Jayhawkeye
Jayhawkeye
Kansas City
Software
yes of course I know the range loss, but 47 percent is crazy.
Redline
Edina, MN
I did a trip from the cabin in Northern MN back home to the Twin Cities on Sunday. I got 1.72 mile/kwh. That isn't a 47% loss. Temps were -12 over night and -5 my entire drive. I was also going 75mph on the highway.
Jayhawkeye
Jayhawkeye
Kansas City
Software
that’s why I’m posting what I’m posting. Perhaps something is up with my vehicle? I’m reporting a 47 percent loss and roughly .50 lower mile/kwh. Even after pre conditioning.
Redline
Edina, MN
Could be...maybe keep testing and if you're getting the same results, submit a ticket.
freshpow
Of course there is a large range hit in cold temps but the 47% figure you “calculated” and keep harping on is some hocus pocus math, as others have mentioned. You said your mile/kwh is down ~.50…47% loss implies you were only getting ~1 mile/kwh in warmer temps. Impressive if true!
Jayhawkeye
Jayhawkeye
Kansas City
Software
I just talked to Rivian, and they said I should expect range reduction of 50 percent.
Jayhawkeye
Jayhawkeye
Kansas City
Software
correct. I am getting between 1.1 and 1.3.
HyperionMark
South Dakota
R1T and Model Y (previously a 3 and X)
Absolutely. Lots of documented cases for a decade now of EVs losing up to 50% range in the very worst conditions. That being said, most of the winter should be more like 20-30% range drop.
emoore
you get 1.1 to 1.3 when it's warm outside? If so that's really low. Unless there are a lot of very quick trips you should be getting close to 2.0 when it's over 50F. What wheels do you have?
Jayhawkeye
Jayhawkeye
Kansas City
Software
no, when it’s cold outside. My whole diatribe here is about losing 50 percent range in cold weather, even when pre conditioning. I was surprised to hear Rivian tell me just now I should expect a range of 150/50 percent reduction in cold temps.
When it’s warm, I’m at a respectable 2.1-2.3.
emoore
ok that makes sense. I agree with 1.1-1.3 when it's really cold outside and you are making shorter trips. I think that probably gets closer to 1.7-1.9 if you were to use 80-100% of the battery.
Jayhawkeye
Jayhawkeye
Kansas City
Software
So do you guys charge to 100 when it’s cold then? I barely made it to work/back then the airport/back one day, and it was a total of 105 miles when I started the day at 80/233 miles.
