Jprime84
- Joined
- May 23, 2024
- Threads
- 2
- Messages
- 14
- Reaction score
- 11
- Location
- North Carolina
- Vehicles
- R1T DM/Standard
- Thread starter
- #1
Electrician that I have worked with estimated an install for me today, and it came out a lot higher than I had hoped. Looking for sanity checks here, or to see if anyone else had something comparable.
My understanding is that because my breaker box is nearly full, they have to rewire 4 of my existing breakers into 2 tandem breakers to make room for the new 60a circuit. They are using conduit in the garage for about 20-25ft from the panel to the install point. The cable for the new circuit is 6 gauge rated for 65a. I am located in central NC.
I also asked about just wiring up a NEMA 14-50 outlet in the same location, and the estimate was $1700 plus permit (and no charger cost), with the same need to redo several breakers to make room. This is what leads me to think the higher cost has more to do with the work in the box than it does the new circuit.
Thoughts?
edit: I did it
https://www.rivianforums.com/forum/...ome-level-2-wallbox-install.28618/post-552804
- Wallbox 48a Pulsar Plus - $699
- Permits - $199
- Circuit - $2000
"Run a new 240v 60a circuit for a wall box charger on the front right
corner of the garage outside facing the driveway. Come from the main
panel in the garage. Pipe down the wall over the side door to the front
wall of the garage. Run wire outside and mount the charger outside
facing the driveway. Includes installing two tandem breakers in the
panel to make space for the new breaker."
Thoughts?
edit: I did it
