Leaking Washer Fluid?
dhiley27
Damian
San Diego
HI, A few days ago I realized washer fluid was low, I topped off, then a few days later, empty again.
Today I realized washer fluid is leaking from bottom of reservoir...Any advice? Sounds like a service issue.
How "Adventurous" are you? Or maybe more importantly.. how far are you from your Rivian SC?
If you're quite a few miles away.... remove the front trunk tub and see what gives.
dleepnw
Rivian, Toyota, Lexus
exact same thing happened to me. low fluid message. i refilled with one gallon. noticed a pool of liquid around the front right corner of the vehicle a couple of hours later. it didnt leak out all at once and its a slow leak. eyeballing it id say most of it pretty much leaked out. opened a service ticket.
--0------0--
East Coast
The same thing started for me two days ago. I submitted a ticket and haven't heard anything yet. I haven't taken it off-road or done anything adventurous around the time this started. Do we have any ideas about what could have caused it to start leaking?
FirstStateR1T
Newark, DE
Too many to list, I have a problem!
Mech. E/GM/COO
If you're the DIY type I'd give it a go. Could be a loose hose on a fitting or a seal where the pump meets the container. My 911 was notorious for this and was an easy fix once I accessed the area.
averagejoe84
Joe
Saint Louis, MO
2025 R1T TRi MAX
You all have any luck getting this fixed? Mine is leaking too, less than 1000 miles on the truck..
ryanjburry
Mill Valley
2022 Rivian R1T, 2019 BMW i3S
Reviving old thread here...my new-to-me 2022 R1T is leaking windshield washer fluid. Picked up the truck from a dealer 10 days ago, got a low fluid message within a few days so I filled it up figuring they had not, then I started noticing it pooling around the right front wheel and today I got the low fluid message again.
Is this the sort of thing that requires a SC visit or can a mobile tech handle it? Has anyone tried to access the area themselves? Not seeing many threads on this in my forum search.
TIA.
