Now they tell us!
I'm not a fan of the CT, but the photos I've seen are of external contaminants (fallout or rail dust).
My R1T is covered in external contaminants pretty frequently just by driving it on the road.
sfvR1S
James
Los Angeles, CA
CRE
Not a fan of CT/Tesla/Musk, but no schadenfreude with their struggles.
Krusty
Western Massachusetts
65 Ninety Eight 90 Supra 90 Range Rover
Business Owner
Musk can do some cross branding and start selling CyberRain-X.
mabowden
Socal
Toby Flenderson
Still beats the weak body panels the R1T/R1S has.
At least you can wrap a CT.
Still wouldn't want to buy a CT though due to a hideous design.
Eh, most trucks are going aluminum due to weight savings for EPA MPG's. Ford F150 body panels are the same. When I bought the R1T knowing it is aluminum skinned I knew that I would be getting some PDR done at some point in the future (Now I've owned the truck 15 months and did 1 PDR appt that cost $150 for 2 dents)
Herb
Herbert
Ohio
911, John Deere, R1T max DMP
Not a CT fan, but that picture is clickbait doctored: Tesla CT's are Rusting There's no way that the bottoms of the doors are rusted out. No 300 series SS will produce brown thick rust even it is a modified chemistry. Most of the strength comes from the fact that they use cold rolled sheet (not annealed) and I don't believe the chemistry is so special. The first few microns of any SS react chemically with all sorts of things. In fact the reason why SS doesn't rust is a microscopic layer of chromium oxide from air exposure. If scratched it'll recover almost immediately and much faster than a brown iron oxide can form. If it gets too hot, oxygen in the air reacts more readily and the layer gets thicker - eventually becoming thick enough to discolor. Environmental acids can also compromise this layer and make it unsightly, but that doesn't mean it'll rust through. Keeping it looking good is whole other story. Chemical passivation will pull chromium to the surface and will make it act more like chrome plated metal. Polishing the heck out if will make the chromium layer shiny and it'll look and behave more like your SS sink and less susceptible to surface corrosion. I have not laid hands on a CT, but the surface appears lightly brushed, not polished, making it almost impossible to look pristine after exposure to fingerprints, bird crap and maybe standard issue acid rain. I would wrap this thing on day one before it becomes blotchy. Paint is hard to beat for making cars look great. The CT body is an experiment gone wrong. They can't press form any three-dimensional shapes because the material has no such forming capabilities. They can only bend it along straight lines. All cars made from this material will look a like mini-me of the CT. The lack of crumple zones turns it into a road weapon. I do believe Tesla engineers saw this disaster coming, but Elon got his wish.
EDIT: body panels are magnetic => not a 300 series stainless => cheaper 400 series with less corrosion. 3min 46sec: Tesla Cybertruck Review // We Drove It Over 500 Miles...And Oh Boy (youtube.com)
Thanks https://www.rivianforums.com/forum/members/no_name5330.8413/
I agree that the image is photoshopped. I'm assuming that the actually corrosion they are seeing is more likely pinpoint surface spots distributed across the body. The corrosion pattern shown in the picture is not possible on a 2 or 3 month old CT.
Years ago, Weber Grilles switch from 304 to 430 on some models. My 25 year old Genesis grille is 304 and is still perfect. My 3 year old Genesis grille is apparently 430 and has rust spots all over it. That one is at a beach house with salty air, so it is harsh, but it still pisses me off.
Herb
Herbert
Ohio
Cost savings, but I'd rather pay 20 bucks more. 300 series is non-magnetic, making it easily distinguishable from cheap 400 series. But I have read somewhere that Tesla uses a modified 300 series. Not sure, though. Now I'm gonna have to carry a magnet in case of a close encounter of CT kind.
bdwalters
Austin, TX
R1S, Model 3, Model Y
Hardware Engineer
I live in Austin and have seen a number of Cybertrucks live. I can verify that they are all filthy and covered in fingerprints. I’m a little OCD, so it would drive me crazy. I would have to wrap it.
Acoustic71
Acoustic71
Volvo XC70; 2022 Rivian R1T
Program Analyst
Rivian R1T R1S Now they tell us! GGYcM4_WQAAKHTo
zymolysis
Ross
Phoenix Arizona
third party service
Even 300 series can be somewhat magnetic where it has been worked.
"By using a thermal process or work hardening (e.g. bending, drilling, etc) austenitic stainless steels can be partially magnetic, forming ferrite in some areas. As a result, austenitic grades exhibit a slight magnetism at mechanically operated edges like sheets."
There's an enormous gap between rusted out and looks like shit because of the rust. The latter won't take much.
