Firewired
- First Name
- Richard
- Joined
- Aug 6, 2022
- Threads
- 11
- Messages
- 97
- Reaction score
- 97
- Location
- San Antonio
- Vehicles
- EL Cap R1T, Model 3,
- Thread starter
- #1
I can confirm the OBD-II port which is to the left above the brake pedal works for power. I know that we don't have all the pins, but we do have three pins, including the pin that is connected to the 12V battery. Traveling I wanted a functional dashcam when on the road until Rivan's promised OEM solution goes live. I wanted to share both options I tried, both of which work.
I installed the Garmin Dashcam MIni 2 first, with one camera facing forward and the other facing rearward. Garmin has an optional OBD-II plug and I can confirm that both cameras worked fine using the OBD-II port. For me, I found the Garmin software extremely buggy, and at most times it was really difficult to view the recorded footage. I could see thumbnails of the clips of the recorded video, but trying to view them via the app would just spin and spin, and repeatedly reconnect to the cameras. I was unsuccessful over 90% of the time and I realized if I stayed with this I would have to pull out the SD card to download the footage. Going the Garmin route for me was $129 for each camera, $20 for each Micro SD card and $49 for OBD port adapter $327 and required running wires from front to back. Installation took me about 45 minutes carefully running the wires.
After deciding the Garmins were not working out, I next installed the new Ring Car Cam which I got on ebay because they are in short supply for $275. This has the OBD port adapter included, which works perfectly via the Rivian OBD port. This one was much faster to install, being it just has a front and cabin view. It took me around 10 minutes to install the one wire from center dash to OBD-II port. This will be the one I am staying with until the Rivian OEM solution comes out. Accessing the footage from the cameras is quick, and I think clear enough (1080p) front and back. The only downside is after the first-month remote access is $6 a month or $60 a year because the Ring has it's own cellular connection which the Garmin does not.
