Only able to program 8 garage doors
Feetdry
terry
Samish Island
Hydro 84
medical sales, almost retired
I have 5 doors programmed but I have to be careful as I drive within range, that the correct door shows up on the screen. Can't tell you how many times that I have opened the wrong door by just pressing the wrong door when it comes up on the screen...
Time2Roll
2026 R1S Quad - 2001 F150
practicle solution that is care agnostic - does require wifI connection at each location i believe
Yes and I assume the OP works for people with garage wifi. Frankly I would be more comfortable with the garage opener reasonably secured on a personal phone vs possible random driver of the vehicle.
Time2Roll
GJ: is gate opening a thing with Rivian?
I have two garages and a gate programmed. All LiftMaster equipment tied in with cameras and MyQ phone app. Yes all needs wifi.
lefkonj
Jeff
New Jersey
Gen2 R1S Tri, I4-m50
There are plenty of apps for this situation, 8 is more than enough.
CharonPDX
Charon
Cascadia
InfoSec Geek
Seeing the headline, I was thinking "zeroth world problems", but the use case here is actually a legit use case.
But the big question is - what did you do before having the Rivian? A ton of clickers? Three "HomeLInk" buttons plus slightly fewer clickers?
It sounds like the primary complaint here is "Rivian said you can do 16" so while still in a position better than pre-Rivian, not as good as expectations were set. As others have pointed out, Gen 1 supports 16, Gen 2 only supports 8. So sounds like whomever you spoke to at Rivian didn't hear that Gen 2 has a lower limit.
