Stripped TP55 Bolt - how to extract?
This worked for me (after many other failed methods/attempts)- Topec 36mm bolt extractor. It was alot easier than expected. If your reading this thread, you're probably in a similar jam, trying to figure out how to get that stripped bolt out of your truck. Hope this helps!
This one? https://a.co/d/7g9I63Z
burrito
Jason
2023 R1T Quad
Shoutout to t-bone! I used the Topec 36mm extractor as recommended by t-bone and it worked like a champ to remove the two stripped bolts -- one that I stripped and one that was most likely stripped at the factory. A word of advice, if you are trying to install the EVBase running boards DO NOT use the L-shaped tool that it comes with, or you too will strip the bolts. Spend a few extra bucks on a quality Torx Plus 55 bit and save yourself a lot of frustration.
They ship theirs with a cheap IKEA-esque L-shaped TP55? tsk tsk tsk
I used this TP55 bit with a impact driver and had no issues. Being a brand I've never heard of, I had doubts. But, in the end, didn't even need the recommended extractor kit. Since I forgot to return it, if anyone needs it, let me know.
Muir
Patrick
Fort Collins, CO
Rivian R1T dual max
just a note that the ev sportsline boards come with a tp55 bit that fit perfectly when I did mine. I used a breaker bar and held the bit in place with one hand while applying pressure. All came out just fine. Then used a torque wrench and blue threadlock. Don't recall the specs but they were included in the ev sportsline instructions and set by Rivian.
Have to agree that these kinds of bolts are a pain and seem poor choice vs a hex bolt.
crashmtb
Man oh Manitoba
torx plus in particular is much more assembly friendly than hex head or even normal torx.
also torx/torx plus is much more suited to a flat or button head fastener than internal hex because it's way harder to strip out the head
Epzey
E
Does this grab the outside diameter of the head?
Robot Overlord
Northern Virginia
Great to know. I have a set of EVBase running boards to install. The original purchaser didn’t install them on his truck. Another person told me to be sure I use a TP55 bit after he stripped a bolt using just a T55.
Research EVBase thoroughly before you proceed. Unfortunate you gave them $ already.
100jacks
Beau
I had a similar issue with a smaller torx screw I couldn't remove from the jounce line. I measured with the wrench and cut the edges off precisely with the angle grinder, so it was fitting in the wrench 🔧. Then I was able to un-wrench it. I would be careful on your case as it's very close to the chassis.
Cal
Cal
Tesla plaid, 2025 R1T Calif Dune
Same question here. Do you have to square the existing round head by grinding it first or just slip the closest sized extractor socket over it without modification.
Before you resort to permanently alter the factory bolt... I would first heat the offending fastener with a soldering pencil to soften any thread locker it may have. Then slip the closest size extractor on to the bolt head. 36 mm is what's been mentioned in this thread. You might even try a mallet on the extractor, to give it a good initial bite.
Reactions: Cal
Cal
Cal
Thanks!
Cal
Cal
Wonder if I should just replace them with a regular hex headed bolt.
That is what Goat Fabrication ships every one of their sliders with. If that's not what you're installing, and the hex bolts are compatible... I don't see why not.
Reactions: Cal
