Portable Jump Starter
savethemanual
Earth
Future R2
Not even close. Can you please just stop making things up?
Alternator/Starter...who's keeping track, close enough. 🤣
Edit: Actually many modern ICE vehicles with auto start stop systems, the Alternator is the starter motor too (Integrated Starter-Generator). I believe these motors act as a very mild hybrid system.
dradam
I keep a tool kit in the trailer hitch to get into the frunk if the 12v dies. On roadtrips I keep a charged SLA in the frunk with post adaptors. Rivian proactively replaced my single 12V but still have never needed my setup.
Thebandit
Subaru Crosstrek, Ascent
Man that's not a bad idea. A LiFePO4 might be a better idea if you already have a charger for one. I might do that.
dradam
You can see my set up in this post:
https://www.rivianforums.com/forum/threads/12v-battery-replacement-megathread.52467/#post-896312
I used the full throttle SLA because the dimensions/terminal orientation fit. Charge it with a NOCO before road trips but have never used It. the posts are from Soonish.:
https://soonishev.com/products/battery-post-relocator
I designed the carrying case and shim. 3D print Gcode here:
https://www.printables.com/model/1387546-rivian-shim-and-cover-for-a-backup-replacemant-12v
Hope this helps.
Thebandit
Hope this helps.
I was thinking a smaller battery that could just be hooked up directly to the jump ports. This is a solid setup too.
dradam
Makes sense , but if it is in the car you would still have to be able to get in .
I think tht the rear jump ports will at best charge the existing 12V but if it is not chargeable then SOL. That is why I have leaned towards being able to directly remove and replace the 12V(tool kit in frunk). I may not clear codes but hopefully could get moving.... if the 12V is the issue. All theoretical for now, but gives me some comfort on long trips.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
I'm used to mass confusion in electrical threads, it can be a complicated topic. The amount of bad info and just made-up bullshit in this thread is over the top.
dradam
Thank you for your comment. Can you enlighten us as to what you think the best route would be if you were on a road trip and your 12 V died. How would you be prepared? Thank you.
SwampNut
Carlos
Peoria AZ
Geek
dradam
Jeremy3292
Jeremy
South Carolina
R2
Sorry, Jeremy. Was responding to swap nut.
Please see my earlier post
You can get the battery as posted. The terminal posts for connection is posted at sooisnh.com and download and 3-D print the shim and cover if you want to carry your back up battery in your frunk . Hope this helps. Unfortunately, it will take some effort on your part to put this all together.
Yeah so there are no ready packaged solutions? That’s shocking tbh.
