Possibly the most expensive charging session ever
iamnid
Mercedes EQE, Rivian R1S
It seems to be to be one of three things:
1. It's a dual charger set up and someone was charging in the spot to the right. The Rivian was desperate for a charge so they parked in the handicap spot to plug in.
2. It's a single charger set up and, same as above, it was an emergency situation so the Rivian parked in the handicap spot.
3. The Rivian driver is a jerk and decided to park in the handicap spot even though they didn't need to and threw caution to the wind.
I think the 3rd is the least likely option.
mzdds
mzdds
2022 Tesla Model S, 2023 R1S
Dentist
Only the 3rd one applies. Double charger and there was a free spot. Not paying attention but they did have the the time to back in and get the rear tires over the concrete curb stop, open the app and plug in. The funny thing is that by backing in, they made the painted handicapped sign on the ground super visible.
C12farmer
2025 R1S
They are not going to get out of a ticket. Despite where the charging post was placed, that was not a designated EV charging spot. It is clearly marked "Only" on the handicap sign.
Best practice is to take any other non-accessible spot first.
EVG-250 Electric Vehicle Charging Stations ADVISORY: EVG-250.1 General. While there is no positive requirement to provide electric vehicle charging stations, when they are provided a portion of them should be accessible. When co-located with parking spaces, electric vehicle charging is considered the primary function of these stations, not parking. Accessible electric vehicle charging stations are not to be reserved exclusively for the use of persons with disabilities. They should not be identified with signage that would mistakenly indicate their use is only for vehicles with placards or license plates for individuals with disabilities.
EVG-812.6 Identification On-site electric vehicle charging stations shall be identified with a sign complying with EVG-812.6 and shall not be identified as or provided with signage required for accessible parking spaces. EVG-812.6.1 Language Provide a sign containing language stating “Designed for Disabled Access - Use Last” in addition to the signage identifying standard electrical vehicle charging stations. Where only one electric vehicle charging station is provided the sign shall contain language stating “Designed for Disabled Access”.
Depends, was this outside of a Subway?
Treebeard
Matthew
Vermont
It sure looks like they expected you to use the stall to the right - the one that had that nice green electric charging sign.
Is there something out of frame that made you think you were supposed to park in the handicap spot?
There are a bunch of scenarios here that could have resulted in parking the way they did. The question is, you pull up to a charging location and all spots are taken except for the HD charging stall. Do you wait or charge. Some places have HD charging stalls and some do not. Some have van accessible stall plus a regular HD stall. I used a Tesla charger that required me to take up some of the HD hashed area. I stayed with my truck in case somebody came along that needed the room. I would have moved if this happened.
Treebeard
Matthew
Vermont
What if someone was parked in the charging spot and not charging. Or someone was in that spot and charging. Before you go off name calling, know the whole story. So maybe this HD spot was the last charging spot available. If so then the above rules state that you are allowed to use this spot.
Kitsap, WA
The issue with the parking spot is that whoever installed the double charger placed it one spot too far. It should have been centered between the 2 spots next to the handicapped spot. However, it is clearly marked on the ground as well as the signpost. I almost did the same thing months ago.
Did you get a look at the back of the Rivian? Perhaps their license plate is a handicap plate, and both you and the ticket provider missed that due to their bumper parking job. Or maybe they forgot to hang their handicap placard?
Y'all are so quick to jump on the "what an asshole" train, somehow that's more believable than someone is 1. handicap 2. forgetful & 3. Drives a Rivian, or perhaps so busy helping their wheelchair-bound grandma they forgot to hang the placard.
why would they back in?
Wheelchair grandma was the passenger?
mzdds
mzdds
Dentist
Nothing but a regular plate on the back. This spot is in Aliso Wood Canyon wilderness. Make your own conclusions.
It has to be a designated EV charging spot for that rule to apply, this is not, it is a standard Disabled Person reserved parking spot.
I am responding just so people are aware, do not use these spots to charge unless the sign specifically states it is a charging spot.
Treebeard
Matthew
Vermont
So you can see if there is no other signage behind the truck? Maybe he is a dirt bag for parking there, but you can’t see the whole story.
HaveBlue
You are all incorrect, lol. You cannot have conventional EV charge spaces and then not have an ADA compliant EV parking space for a disabled person to also charge. Though both plugs are allowed to reach conventional spaces, one must be ada accessible. Here's an example where that is implemented. The post reaches two normal stalls and an ADA one:
Rivian R1T R1S Possibly the most expensive charging session ever 1000023409
Those are actual Disabled Person spaces, you cannot park there to charge unless you have the proper plates or placards.
The ones I’m referring to and that CA law allows for usage while charging are spaces like these that are marked as Disabled Person spaces but also EV charging spaces. You can park in these while charging without the disabled plates or placards. They should be the last spots to be used but anyone can charge at these.
Rivian R1T R1S Possibly the most expensive charging session ever IMG_3837
bigsky
MUM
MUM
No handicapped license plate or placard hanging off the rear-view mirror. Indeed, no license plate at all. Consider yourself fortunate if you got away with this unfair-to-handicapped deed with a $250 fine.
HaveBlue
Those are also actual handicap spaces. My point was just that accessible spaces are required at public charging. Just like accessible tables and restrooms are available at restaurants. It's not banned to sit there but the venue must have them. Some charging sites are retrofit on existing lots so making an ADA space reachable by a plug is the way to go.
You're point on the law is the best of all worlds where full utilization can happen.
True Brit
Out and about
A minimum fine of $250 for the handicap parking error but I think it could be up to $500 if it's a first offense, then one can hope for a "fix it" for no front plate but I believe it could be a $196 fine plus court costs.
People make choices and often it depending on morals and income level.
On the other hand, maybe they left their placard in their other car, and proof of said placard would probably get the ticket dismissed. Additionally, the front plate and holder might have fallen off and they reported it lost/stolen, which again would get the ticket dismissed. ?
