Universe93B
Raleigh, NC
Audi SQ5
Yes, but that is only ~75 miles to South Hill. To Petersburg it's ~125 miles where I-85 ends and it slows down before that anyways. R2 has a 250-300 mile range. So the point was no one is averaging 80 mph straight for that long unless they're on a desert trek out west or something. Averaging 70 mph is far more likely, which is why a 70 mph range test is key and applicable to everyone's real world use.
I do a round trip on the same day, traveling back in the evening for a business and work. I wish EVs are better at constant speeds around 75-80mph.
I think you are defending EVs and the R2 a little too much. I think it’s better to acknowledge this issue in EVs in the current state if we want EVs to compete better with ICE.
Worth noting, the drop in efficiency is related to drag not the speed. If you are on a busy highway and are not in the lead vehicle the drop off doing 75-80 is not as bad.
It is when you are the pace setter that you really see the drop off.
In my R1S 75 is not horrible but on the highways that have an 80 mph limit I tend to do 75-78, that extra few mph over seems to be a really big hit on efficiency. My last trip around 7k doing posted speed limit with the above exception I averaged 2.25 m/kWh. My guess is the R2 will be closer to my older Model S at just under
Jeremy3292
Jeremy
South Carolina
R2
Sure, but then you just charge at home after ~150 miles so it's a non issue? I'm not defending anything; I've long been on the record here a ~100 kWh (vs. 88) battery R2 would've been great. I'm just pointing out a lot of people oversell how much range is needed in their daily life or even road trips. I have no issues with bigger batteries and farther range though.
mcdaniken
Dan
Phoenix AZ
2016 Jeep Renegade, 2023 Kia PHEV Niro
I may have one of the few vehicles on the planet that gets better fuel economy at 80 mph than it does at 70 mph. My Jeep Renegade has a 9th gear that won't kick in below about 80 mph. So i get about 22 mpg historically at 70 mph, and 25 mpg at 80 mph.
zefram47
Rivian R1T, Alfa Romeo 4C
Noting that Air is 14% less dense at 5,000 ft than Sea Level. That translates into about an 8% benefit at high altitude at 75 mph (depending on vehicle). Beware colorado 70 mph range tests!
Air at 32F is also 15% more dense than air at 70F for the same elevation. The difference between 70F and 100F is 5% lower density at 100F.
Mike777
Michael
Ford Bronco, Cadillac Lyriq
Honestly, if that's the case that's really really bad. My Lyriq gets about 250ish going 80 in Texas. Anything less than that in a 2027 vehicle is a poor showing.
Tom's video from state of charge I think is a better example. If it gets 260 going 70 than 240 is probably more accurate going 80 with the 20 inch wheels.
I still dont understand how in 2026 we are still releasing cars at 300 miles of range. Although I'm still getting the R2 average speed limits in Texas highways are between 70-85. Most are 75 and some all the way to 85. You need at minimum a 350 - 400 miles range car coming out today for proper highway driving. Hence why I'm opting for the 20 inch wheels with aftermarket all season tires. This is coming from someone that does monthly long drives in our Lyriq.
I love EV's but there's a reason it's still not appealing to the masses because of this. Not sure why they didnt put at least a 100-110 kwh battery like the IX3 with the efficiency numbers would have been somewhere between 350-380 of range.
Apprunner
So-cal
Tesla M3P
If Tom is getting 260 going 70, no way he's getting 240 at 80 mph. At 70mph, I get 285 miles with my Model 3, at 80mph, i get 230 miles and its a super slippery sedan. At 80mph, this thing is going to get closer to 200 miles. Its good for a boxy SUV.
Pablolibre
Paul
ABQ
Pilatus PC-12
work if I feel like it
I'm heading up to Utah and Wyoming tomorrow. Much of the interstate system there has 80 mph speed limits. I will not be in an EV because of that.
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
The Lyriq's battery has 20kWh more capacity and the vehicle is more aerodynamic than the R2.
NeverFollow
A Galaxy Far Far Away
リビアン
Yesterday in fact a motorcycle passed at around >90, moments later I saw a cruiser pursuit him, he jumped off highway only to jump back on and he was gone, the cruiser gave up almost immediately.
The criser might have keep a video, and not impossible that the motorcycle get a ticket later.
There are few videos on YouTube showing it...
